Question about Microsoft LifeCam VX-1000 Webcam
My LifeCam 1.4 won't work
After installing it, I tried to used it but a windows error keeps on appearing. Also, i uninstalled it and re-installed and the same problem keeps occuring. Also, because of that i can't really do anything with the webcam --- it doesn't let me have a webcam conversation with anyone. I don't know what im supposed to do with this. I don't know if its because of my windows vista or something im not sure. My computer does recognize the ca,era, but the software installed don't.
  • 1 more comment
  • aldancocos Jan 02, 2009
    Sorry, but my Operating Sistem isn't Vista. It's Windows XP SP2. Sorry for forgetting to mention that, but i understand that these cameras work even under this sistem. Maybe is a solution for this.
    Also, when I try to fix the problem in Device Manager, this comment appears: "Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)"
  • aldancocos Jan 03, 2009
    Sorry, the same ****.
    Even Windows sees the device, appears a message, that during the instalation, an error ocurred and the device may not work properly.
    Any new ideas?
This website contains the solution for the EXACT problem you describe. I had the same problem and stumbled across it and it helped a lot.
It's pretty easy.
Open up regedit (Start -> run -> type: regedit, hit enter)
Navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{6BDD1FC6-810F-11D0-BEC7-08002BE2092F}
Double click on "LowerFilters" delete any value found. (Should be: lvmvdrv or LVUSBSta).
restart your computer.
Should work now.
Posted on Mar 12, 2009
  • 8,596 Answers
Go here to get the Vista-comaptible software:
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
-Tha Mp3 Doctor
Posted on Jan 02, 2009
  • Corey Knoettgen
    Corey Knoettgen Jan 03, 2009
    Uninstall the software completely - the installation never completed or caused a conflict, hence the error message. Once uninstalled, restart the computer and reinstall the software. Make sure your webcam is not plugged in during this process. After the installation is complete, restart if the program asks you to. Otherwise, plug the camera back into the computer and see if the error message persists.
  • Corey Knoettgen
    If you are running the software from a CD, it is possible that the software on the CD is corrupt. You can get a clean version of the software from Microsoft here:
    http://www.microsoft.com/hardware/downlo...
    Also, here is Microsoft's complete information on Code 19 Errors:
    Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. To fix this problem you can first try running a Troubleshooting Wizard. If that does not work, you should uninstall and then reinstall the hardware device. (Code 19)
    Recommended resolutions
    A registry problem was detected.
    This can occur when more than one service is defined for a device, if there is a failure opening the service subkey, or if the driver name cannot be obtained from the service subkey. Here are some things that you can try to resolve this problem.
    Uninstall and reinstall the driver
    Uninstall the driver from Device Manager and scan for new hardware to install the driver again.
    You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
    1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
    2. Restart your computer.
    3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
    Revert to the most recent successful registry configuration
    This content is designed for an advanced computer user.
    The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores all the registry information and driver settings that were in effect the last time that the computer started successfully.
    For more information about the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base:
    307852 http://support.microsoft.com/kb/307852/ ) How to start your computer by using the Last Known Good Configuration feature in Windows XP
    Edit the registry
    As a last resort, you can edit the registry directly. For more information, see the Registry Reference in the Microsoft Windows 2000 Server Resource Kit at the following Microsoft Web site:
    http://www.microsoft.com/technet/prodtec... http://www.microsoft.com/technet/prodtec...
    The registry information applies to Windows XP.
    -Tha Mp3 Doctor
LifeCam VX-6000 Doesn't Work... LifeCam.exe doesn't start up
Did you try uninstalling and reinstalling the software again?I suggest you first uninstall it and then download the software again from the below link and install it.
http://download.microsoft.com/download/6/6/6/6663B667-3D5E-4637-A615-80EC6BA1E4AC/LifeCam3.0.exe
Let me know the result.
Thank you for using fixya.
Dec 20, 2009 | Microsoft LifeCam VX-6000 Webcam
I keep having windows installer trying to reinstall my camera on every start up. It tells me it failed to install the camera and directs me to go to the following support link...
Try Installing NET.Framework And Try This Software: "Driver Genius" After Installed Plug In Device (Camera) Click SCAN And Install Drivers (note u can chose whichever drivers u want to install), Very Easy To Use Software
Nov 21, 2009 | Microsoft LifeCam VX-6000 (68C-00001)...
I keep getting the message "Initialization Error".
Do you have DirectX installed on your computer ?
For mor information read :-
http://support.microsoft.com/kb/933311
Aug 15, 2009 | Microsoft LifeCam VX-1000 Webcam
Cant connect to lifecam
There may be a clash between lifecam and MSN. close MSN and alll other IMs. uninstall lifecam. restart the PC, install webcam SW with the cam unplugged. After installation plug the cam ina USB port and let Windows read the drivers and install the cam, Once that is done, now you can configure the cam in your IMs one by one.
Aug 07, 2009 | Microsoft LifeCam VX-1000 Webcam
I have tried to install the software that is given from the link and several others but it keeps appearing an error message saying there is an error during installation. What can I do?
Have you uninstalled all the old webcam software on your pc ?
Download Revo and scan your computer for any webcam software - uninstall whatever you find.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Back this up with a manual scan - Start > Computer >> Local disk (C) >>Program files
Look for any folders that may be webcam related especially Lifecam
delete the folder if found.
Install software from Microsoft support. Select your OS and type Your webcam model into the search box
Close all programs when installing software and dis-connect webcam.
Jul 20, 2009 | Microsoft LifeCam VX-1000 Personal Web...
Blue screen appears when I instal Microsoft nx-6000 cam
hi adrian,
thank you for using fixya.
you may have encountered that blue screen of death error because of an IRQ conflict. this cane be caused by a conflicting resource for computer components. much like 1 car battery being used by 2 cars at the same time.
o have this resolved, it is best that you have the camera replaced with another model or you can try to remove other USB devices plugged into your computer until you find out what is causing the error message or the conflict to your new Life Cam.\
hope this helps.
regards.
voodoo
May 14, 2009 | Microsoft LifeCam NX-6000 Webcam
Error Msg: Problem occure during Hardware installation
Having Nero installed can cause this problem. This is from the Microsoft Knowledge base. There are some other programs that can cause this problem. Search "Lifecam Program" I believe I have tracked the problem down to this. I have not uninstalled Nero yet, But Nero crashes when trying to launch it video utilities. So at this point I am presuming that tere is a conflict.
Jan 11, 2009 | Microsoft LifeCam NX-6000 Webcam
Software Installation of Microsoft LifeCam VX-6000 terminates with an error "Insufficient free space"
I purchaased MS Lifecam from Walmart at a bargain price of $50.00 yesterday. I quickly installed the s/w on my windows 2003 XP under 5 mins. The camera worked for exactly 20 mins. I opted out from installing the Live Messanger ( don't need it). However the s/w crashed within 20 mins, complaining of a fatal error, which it could not Debug, but insisted on sending off the report to MS..which I declined. After trying to reload the s/w on the same computer for 3 more times, which involved remove and re-install..I finally gave up on the 2003 XP. I then tried to load the s/w on my windows 7 laptop..got the same error message. After messing with it for at least 5 hours, and ruining half my day, I returned the product back to walmart and got my money back. What a scam!! The MS Support site tells you to reinstall windows 7 and then try to reload the d- -n!! s/w again. What kind of Freaking solution is that??!! BTW I have plenty of space on laptop, 80 gigs..so space was not an issue.
Jan 10, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
hey ,the installation software that you are using might be corrupted.
you can download the software for your cam from this link
Download Microsoft LifeCam VX-3000 Now
Dec 01, 2007 | Microsoft LifeCam VX-3000 Web Camera
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
Microsoft LifeCam VX-1000 Webcam Logo
827 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
