Question about Samsung Helix YX-M1Z MP3 Player
Will not turn on?
I just received a Helix and drained the battery for charging and now I cannot get it to turn on. It has been charging for more than 6 hours and it still will not power up. What should I do?
0 characters
1 Points
I can't turn on my V-Touch: I have to plug it in the charger everytime and as soon as I unplug it, it turns off and won't turn on. The battery icon in the corner says the device is fully charged. Plus, the...
This problem is due to a bad battery. All rechargeable battery have a charging limit of upto 1000-3000 charges, after that it will loose its ability to get charged, so you will have to replace the battery.
Jun 05, 2010 | Visual Land V-Touch Digital Media Player
PMP-120 Battery Discharges too quickly
you will have power through the usb port, so leave it plugged in.
Even when it is shut down it can drain batteries.
Feb 25, 2008 | iRiver PMP-120 Digital Media Player
My Helix hangs...
Update ur drivers this will fix ur problem and im sure u must be having the manual go throught it.
Don't forget to rate me as fixya..
Feb 01, 2008 | Samsung Helix YX-M1Z MP3 Player
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Ipod Nano 5th Gen. 3 months old and died--won't restore either.
A possible problem with the battery. Battery life depends on how you frequently used the devised and how you handled the proper cycle to charged and drained the battery.
Battery charging should complete it's charging hours and you have to properly fully drained the battery at least once a week, this will make the battery life go longer.
Initially try to plug and connect the Ipod into your computer and see to it that it was turning ON, or it was giving any sign that it was responding when you connect it to the computer.
Is there any incidents happen that you got a problem on charging the unit, or any like incidents like power outage on the area or a short circuit on the device charger?
Let me know here again for further instruction and clarification.
Feb 23, 2010 | Apple iPod nano
It won't turn on. The battery charge light is on and have been charged for more than 8 hours. however, the light doesn't blink at all no matter how long you've been charging it. When charger is removed,...
Either the charging circuit is faulty, or the battery has drained and the safety circuit has disabled it. If you have a warranty send it back, if not, take it apart and try charging the battery from an external 5v source. Do not leave it this way for more than a half hour as it will overheat and could explode.
After it's gotten a bit of a charge (if you have a voltmeter check that it's over 3.7 volts) put it back in the player and it should start up. Now try charging it the regular way. If it doesn't charge further then the charge circuit is damaged. Try a cell phone repair center, they should be able to help.
Jul 02, 2009 | Archos 605 WiFi Digital Media Player
Shows full charge but dies within one song
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.since you have over charged and drained completely , the battery must have been busted.please replace the batteries and if still isnt turning off, check the keypad for any faults.hope your problem is tackled..have a nice day
May 22, 2009 | Microsoft Zune JS8-00001 Digital Media...
5th generation ipod will not charge
It could be something wrong with the main board or a faulty replacement battery.
hope this helps at all.
good luck :)
Oct 04, 2008 | Apple iPod MA446LL/A MP3 Player
Microsoft Zune 30gb black battery/charge problem
When the battery turns green, take it out so it doesn't drain.
Mar 26, 2008 | Microsoft Zune JS8-00001 Digital Media...
Battery Life
it is normal
to charge it of the mp4 and charge it
Mar 11, 2008 | iRiver E10 Digital Media Player
MP3 & Digital Media Players Logo
22 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
