Question about GE Spacemaker JVM1640SJ Microwave Oven
RE: Sharp R 1870 F microwave/convection in motor home. The unit turns off at 59 seconds. It was under warranty. Monaco sent me a replacement. The unit installed in motor home has brackets the new one does not. I want to simply exchange outer cabinets and re-install new unit in old cabinet. How do I remove outer cabinets? I have removed screws but cabinet does not seem to move. Thanks, Peter Salem, Oregon 503-936-0017
    Problem Solver:
  • 13 Answers
Yes its possible
Posted on Jan 02, 2009
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
I just had an appliance repair man check my Sharp R-1870 microwave for the 59 second shut off problem. He said it was the main circuit board. Has anyone run into this problem. Everything I google says...
I've had a similar problem with a 1983 Sharp Carousel microwave. It turned out to be a faulty door micro switch, the contact didn't stay closed inside it for very long.
Feb 24, 2015 | Sharp R-1870 Convection/Microwave Oven
Sharp micro counts down 59 seconds and stops
It seems this has been happening over the last few years. I am a retired appliance tech. My 1870 also started the 59 second routine, Also in a motor home. Pure logic. Had to be the board. New board same results. So now I need to run down a parts manual and possibly service manual, and get the damper switch and motor refered to in earlier posts. Changing out the board was fairly simple. Dropping the unit to change out the other components sounds like it will be a tad bit more difficult.
Oct 14, 2012 | Sharp R-1870 Convection/Microwave Oven
Microwave/convection oven in our fifth wheel will not run past 59 seconds. For example trying to reheat a cup of coffee set at two minutes - it will only run for 59 seconds. I am afraid to try the...
looks like the timer brain has packed up on you,,
how old is it,, it may be cheeper to just replace the microwave as there not very pricy now,,there is very little inside them that you could fix your self, however,, putting your hand inside the back could kill you? so dont try it, play safe buy a new microwave insted
Oct 26, 2009 | Sharp R-1870 Convection/Microwave Oven
No matter what time i put in it cuts off in 60 seconds on a sharp
This sounds like a bad damper switch or motor. Double check the shut off time....... see if it's actually 59 seconds..
When you unplug the unit from the wall for 2 minutes then plug it bad in, you should be able to faintly hear a motor run for a few seconds. This is the damper motor running. This will verify that the motor is operating.....
Also, check the thermistor.
Sep 08, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp r-1870 shuts off after 59 sec
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
Most computers will open this document automatically, but you may need the free Adobe Reader
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jul 13, 2009 | Sharp R-1870 Convection/Microwave Oven
59 SEC NEED TO GET FRONT OFF MICRO
If your unit runs for 59 seconds then stops, the problem is the convection damper motor. (Sharp part # RMOTDA222WREZ).
Unfortunately, you cannot access this from the front - the whole unit has to come down as the entire outside cover has to be removed.
This is a pretty major job and the motor (located below and behind the magnetron tube) is rather hard to remove and get back into place. This is probably better left to an experienced technician. You can call Sharp 1-800-BE SHARP for a referral to an authorized servicer.
Jul 22, 2008 | Sharp R-1870 Convection/Microwave Oven
59 Second shut off
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside (on the right side in your model) that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle in 59 seconds.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have a partial service manual at our site here.
You can usually find a Sharp exploded view by entering your FULL model number here: http://www.searspartsdirect.com
You can order Sharp parts there or from Tritronics at http://www.wehaveparts.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | Sharp R-1870 Convection/Microwave Oven
Sharp R-1874 shuts off after 59 seconds
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
Oct 24, 2007 | Sharp R-1874 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
158 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
