I did try: change fuse as first it was without any lights. Then checked sockets. It started again by itself. Then I reprogram it-switch off-turn on 90'C-press start button- switch on- keep pressing f
    New Friend:
  • 3 Answers
Try this reset, it may work:
-Turn Off power switch
-Select 90 degree washing
-Press and hold Start
-Turn ON power switch and keep pressed Start button 10 sec
-Depress Start button
-Turn Off power switch and turn On again and thats it...
Credit to original poster :)
Posted on Oct 19, 2012
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: washer displays DL error
The FdL fault is a door lock error code. It sounds like you may have a bad door latch. Unplugging it and/or pushing the cancel button will not clear the fault as long as the fault condition exists. At best, you may have to replace the door latch. At worst, the CCU (main computer) could also be bad, causing the fault. The door latch can run about $50. The CCU is about $200. Double check all you wiring first before replacing any parts. I hope this will help you.
Posted on Apr 29, 2007
  • 16 Answers
SOURCE: door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Posted on Feb 27, 2008
SOURCE: Whirlpool Duet won't start
I had a similar problem on my Whirpool Duet Washer model GHW9150PW0. I found the solution here (Scott says his wire was cut, but in my case one wire of the control ribbon cable was frayed because it had fallen out of its holder and onto the tub assembly, part of which is so coarse that it ate through the insulation and wire by friction during the spin cycle). A quick splice of the wire to close the circuit and some tape to keep the cable from falling out of its holder and away from the vibrating, coarse tub assembly did the trick.
- George
Posted on Nov 01, 2008
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
TheMobilian
  • 8220 Answers
SOURCE: Keep getting an F1 code
You must have trash or sediment in your pressure tube hose. b66bfab.jpgRemove it from the pressure switch and blow the stuff out then re-secure the hose and pump out any water in the tub. Then retry. Use this handy dandy service manual as a GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 28, 2010
Testimonial: "Thank you so much! You were very helpful!"
My XE-A201 reset itself overnight. I did reprogram, but next morning was reset again.
Yes, the cash register uses batteries.
Without the batteries in each time you turn the cash register off you are, in effect, performing a master reset.
See page 7 of the Sharp manual here: http://www.sharp-cash-registers.co.uk/acatalog/Cash_registers_xea201_manual.pdf
Thanks,
Ben
Sep 12, 2016 | Retail Supplies
I have a Mercedes E420 1997. I am having tail light issues, all the lights work turn sig., brake, back up, but no tail lights. I have changed out both rear tail lights, bulbs, and checked all of the fuses....
Check for power with a test light(not a dvom) at the tail lamp assembly. Test right at the spot where the bulb socket sits. If you have power then i would check the connection tab on the bulb socket itself for pits or corroded tabs. If you do not have power present at test point then double check the fuse chart and see if it says 'electronic' instead of having a fuse amp rating for the tail lamps. If it says electronic for any of the light circuits then it means their is no external fuse that can be replaced and the problem is most likely internal of the headlight switch. Since the headlight switch is actually a power source for the lights. I would start there at this point. Let me know what you find and if you need anything else just let me know
May 14, 2012 | Mercedes-Benz E-Class Cars & Trucks
Which fuse goes to tail lights 85 jeep cherokee
Don't remember but you can check all of them in under ten minutes with a test light without removing any. Turn the key to the on position and turn the lights on. Probe the small opening on both ends of each fuse with a test light. It should show power on both ends. Change any that don't.
Also check that rear bulb sockets are properly grounded and that the light switch itself is good
Aug 26, 2010 | Jeep Cherokee Cars & Trucks
I have a new battery but my car would not start, but passenger real window rolled down by itself and the dash lights would come on and go off with or without the key in the ignition. Does anyone know of...
TRY PUTTING KEY IN IGNITION SWITCH.TURN SWITCH TO RUN POSITION THE IMMOBILIZER WARNING LAMP WILL ILLUMINATE A FEW SECONDS.KEY CODE IS RECOGNIZED.IF IMMOBILIZER WARNING LAMP ILLUMINATES FOR A FEW SECONDS THEN FLASHES RAPIDLY KEY CODE NOT RECOGNIZED.TRY IT AGAIN FROM THE ABOVE INFORMATION.IF CAR STILL WONT CRANK.THE DEALERSHIP HAS TO REPROGRAM IT FOR YOU.
Feb 15, 2010 | 2005 Acura MDX
Reverse light fuse blows when put into reverse
Unfortunately, many possibilities. If you have time, start by removing both reverse lamp sockets from light assembly(and keep from touching any metal), remove bulbs from sockets, CAREFULLY INSPECT sockets and wires. New fuse of correct rating. Turn key on and try again in reverse.
Fuse still blows: Next place to look is transmission reverse electrical switch and wiring as far as you can trace looking for burned/stripped wires near transmission and wires by sockets
Fuse doesn't blow: Turn key off and install one lamp in socket at a time. DO NOT install sockets into fixture at this time. Test. Remove first lamp to check second. If still O.K., each socket back into fixture(one at a time same as before)and test. Most common problems: Sockets contaminated, wires shorting at sockets, bulbs installed incorrectly shorting to ground.
Sep 25, 2009 | 1996 Ford Explorer
Stumped can get this car to start
if its auto check inhibitor switch also check ignition switch and all fuses
May 26, 2008 | 1995 Pontiac Bonneville
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
