Question about Acer Aspire 9300 Notebook
Is there an external sound control on an acer travelmate 5510?
I had sound on my acer 5510 but it just stopped.
    Scholar:
  • 34 Answers
Extensa 5510 Drivers Recovery Restore DVD/CD
you can find these drivers online Im sure with Acer. Your drivers on that cd are probably out of date anyways. Can always try this DriverPack Solution
Nov 13, 2013 | Acer Extensa 5510 Drivers Recovery Restore...
5510 all in one, my fax has stopped working. I reinstalled the 5510, the wizard set up my fax, it rings, picks up, BUT doesn't do anything else. Try to send and it sounds like it doesn't dial out? It...
First, I would suggest suggest you reset the FAX. If resetting does not solve the problem, you can then read and follow instructions on this link; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669298&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255
1. Remove all of the paper loaded in the main input tray.
2. Press the power button to turn off the HP fax product.
3. Disconnect the USB cable from the back of the HP fax product.
4. Disconnect the power cord from the back of the HP fax product and from the electrical
outlet, and then wait one minute.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the back of the HP fax product.
7. Press the power button to turn on the HP fax product.
8. Reconnect the USB cable to the back of the HP fax product.
9. Replace the paper in the main input tray.
10. Use the HP Fax Test Service to try to send and receive a fax.
Good luck.
Mar 24, 2011 | HP Officejet 5510 All-In-One Thermal...
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
My acer web cam on travelmate 5510 not working ?
just ree-boot your computer or visit webcam reeboot.com
Jan 26, 2010 | Acer Computers & Internet
I dont have a battery driver for acer aaspire 5510 xp
Battery never required a driver for any laptop, but yes some softwares are required to make different plans for battery else no driver is required for battery
Jul 17, 2009 | Acer Aspire 4930-6862 Laptop
Sound driver not installed?
This is the download link for the driver you've specified. If you have problems installing or downloading this please post here so we can follow up with you and further assist.
Apr 06, 2009 | Acer AOpen AW 200 Sound Card
Acer eData Security Management
Mein Problem besteht darin, dass neuerdings beim start die ansage kommt installieren sie acerdatasecurity management neu. wie kann das passieren und wo kann ich dies onlie runterladen ?
Mar 31, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Sounds like you have either a virus or spyware, you can boot into Safe Mode with networking and download Malwarebytes from Malwarebytes.org and run a scan to see if it finds any roue software. When in safe mode run MSCONFIG from Start, Run and uncheck enything that looks suspicious and then reboot.
Mar 01, 2009 | Acer Aspire 4315 Notebook
Acer Aspire 9300 Notebook Logo
117 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
