Question about Frigidaire Refrigerators
WATER COLLECTING IN BOTTOM OF FREEZER WHEN AUTO DEFROST COMES ON
I HAVE A SIDE BY SIDE MODEL MRS22WNGD7 . IS THERE A TIMER OR THERMOSTAT I CAN CHANGE OR ADJUST. EVERY THREE DAYS WATER COMES OUT ON FLOOR. I CAN SEE WATER FLOW WHEN ELEMENT COMES ON
    Genius:
  • 1,036 Answers
This is a result of the defrost element coming on, and melting the ice formed on the cooling coils.
It seems to be doing this correctly, but there is an excess build-up on there to begin with.
Please check the door seals to make sure they are closing properly. Close the door on a piece of paper, and tug the paper to test the fit. If it comes out with little resistance in one area, you may need new seals.
Another cause is that it is defrosting too much - heating the contents, then refreezing. You have to check frequently to see this - or find foods clogged together. The solution to this is to replace the defrost sensor, or the control board which times it. If there are no other errors shown, it is probably the board.
It would be worthwhile searching the internet for the model and "problems" or "ice", as it could be a common fault with certain models, which may point you more certainly to a fix, but I would say the defrost sensor or control board is bad. Replace the cheaper of the two first.
Posted on Jan 01, 2009
Kenmore side by side freezer not cold and there is frost on back of freezer wall
you have a defrost problem,it's not going into defrost,bad defrost heater,defrost thermostat,timer or board depending on what model you have.next time send the model number,it should be in the fridge section,on the right hand wall up near the ceiling.first thing if it has a timer advance it into defrost by turning it with a screw driver or if it has a board remove the bottom kickplate and look for the tech sheet,it will tell you how to put it into defrost mode or unplug it..remove all the food and shelves and inside back wall of the freezer,with a hair dryer start melting the ice around the heater if it has a glass heater on the bottom ,if you can't get it into defrost you can unplug it,remove the two screws that hold the heater into place and look at it,if it's all black inside the glass change it out,you can check it with a meter to see if it's good but sometimes it will read good but like i say if it's all black change it out,if you have a calrod just a black rod going around the coil most likely this won't be your problem,it will be the thermostat,next you have to check the thermostat,it's on the top of the coil,if you know how to get it into defrost,first unplug it,then cut or unplug the two wires going to the thermostat,bypass the thermostat by wiring the two wires together,plug it back in,put it into defrost and if the heater comes on then you know the thermostat is bad,it's a good idea to change this while you're in there anyway,also if you look at it and the top looks like it's buldging off then water got inside it and it's bad,if you send the model number it would be easier to help you but you get the idea,you have a bad part in the defrost section,if you have another fridge you could just shut it down and it will melt out on it's own,then you can check the heater with a meter,the only thing is the thermostat has to be cold to read it out with a meter,like i said it's a good idea to change it anyway,you can cut or unplug the wires and bypass it and see if the heater comes on,if it does come on leave it on,it will help you melt out the ice or cut the wires,remove the thermostat and put it in the other freezer so you can check it with a meter but the best way is to just bypass it,put it into defrost and see if the heater comes on,if the thermostat and heater are good then you have a bad board or timer.http://www.youtube.com/watch?v=z-h541_14ZE copy and paste,this is not a side by side but the thermostat is in the same place on the coil,just remember where you remove it from if you change it out,it has to go back on the same spot.if you need more help send the model number and we can go from there.it's a little tricky trying to tell you what to do without knowing if there's a board or a timer in it.hope i didn't confuse you and good luck
Oct 19, 2011 | Refrigerators
Tip
Freezer working but no cool in Fridge/No Ice making
This is one of the common problem throughout the world. It's because of not going through User Manual before using the fridge. <br /><br />To get better cooling, dispensing water, ice cubes from your refrigerator, please follow the steps. <br />1. Keep temp setting between 3 degree and 5 degree Centigrade.<br />2. Ensure, freezer door and mail door of Refrigerator are closed properly.<br />3. Check freezer fan is working. If struck by frosting behind the freezer, you have to defrost it.<br />4. Defrost cycling is not functioning properly. Because your set temp is less than 3 degree or in minus.<br />5. Auto defrost cycle not activated due to thermostat, timer, heater malfunction. <br />First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it<br />6. Check water line to make ice are not tint or remove kinks in water source line in the back of refrigerator to increase water pressure.<br />7. Check solenoid valve in the rear side of refrigerator back is activated. <br />8. If solenoid activated,no water flow means, have to clean solenoid valve. <br />9. Check shut off arm is not struck due to over ice stores in the ice bucket. Remove it.
on Feb 07, 2011 | Refrigerators
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
Kenmore Coldspot freezer too warm
Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Hope this helpout......
Jul 28, 2010 | Kenmore Refrigerators
My coil in the side by wide freezes solid about every 3 months. this causes the refrigerator to warm even though the freezer stay super cold , what causes this?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Dec 17, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool Estate series fridge/bottom freezer no longer gets cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
I need to know where to find the defrost timer on my amana fridge. this is the 22.6 cu. ft model #sqd26vw. Ive looked in the back and found the compressor but no defrost timer. specifically is it in the...
remove the grill at the bottom of the fridge there is a black box wth a knob sticking out you can turn in only one direction clockwise till you hear a click and the compressor and fan will cut off if running.
Jun 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
