Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Proheat will not **** up the solution after it is applied
When applying the solution for cleaning the carpet, and then passing over the area to retrack the water, dirt and grime, I donot get any pickup and the container for sucking up the left overs, remains empty. The application appears to be working fine, I just dont get any removal. Any suggestions.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yio;
Posted on Sep 30, 2010
Where will I find the user instructions for swan carpet cleaner scw3011
Search Results
    How do i use my Swan Carpet Washer SCW3011 once its ...
    www.fixya.com > Forum > Kitchen Ranges
    Aug 7, 2011 - Bissell ProHeat Perfect Pass carpet cleaner. The cleaning solution container never empties. We run the cleaner all over the carpet and still ...
Oct 08, 2015 | Vacuums
Water and solution do not dispense.
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
Basic instructions and mixture ratio of cleaner and water
I would not leave the solution on the carpet for more than a few minutes! Clean it right away to minimize chances of bleaching out your carpet.
I have a Proheat 2X and and it would not dispense water & cleaning solution. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing. With the dial set to "Tools", I had the same problem.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW on carpet & tool settings. Don't know if this will help you, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 18, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
The bissell proheat is leaving too much water on the carpet
Sounds as though the machine needs a good clean before using again. Remove all the dirt, grease and hair from the transparent areas by removing the covers and then reassembling. Also this can be caused by running the cleaner too fast across the carpet.
Aug 26, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell proheat rug shampooer wont wet carpet at all
heatman101
gfhjdhg
Jun 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The carpet does not look like it is clean
heatman101
dhgjdg
Mar 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell proheat 2x will not send out fluids in hose or floor area
heatman101
tulty
Feb 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
110 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
