Question about KDS K717s 17" LCD Monitor
No power My KDK k717 just died, I tried the power cord on another computer and the cord works fine. Ive had it about 2 1/2 yrs. is it replacement time. Earl the pearl
    Problem Solver:
  • 8 Answers
This is a common problem across many monitors, unfortunately. The problem stems from one of two things, typically.
It is either the Power Inverter board (Inverter Mirage Electronics AD-1700 Rev:F 200-000-170DTL1 VERSION:A) or a weak or dying backlight.
If your monitor comes on for 2 seconds then you can test the backlight by using the controls to get into the backlight brightnes settings on the OSD and turning it WAY down.
If that dosen't work then it is likely bad capacitors on the Power board mentioned above. If you feel adventurous and know how to solder then you might be able to fix this yourself. You need to be careful however because you are dealing with high votage in there and capacitors CAN hold a charge long after you have unpluged the unit. You can read more about this power board as well as how to replace the bad caps HERE.
If that's not for you then I would recomend taking it to a local TV shop for them to fix. The parts shouldn't be more than $20, but labor can be expensive.
Or you could replace the monitor. You can get some nice ones from Newegg.com from around $100. Remember to recycle PC parts responsibly!
Posted on Jan 02, 2009
My HP 2711 monitor went white. I plugged in another monitor and everything works fine on my computer. Ive only had this monitor and computer for 2 months so it should be covered under warranty. i guess the...
Hi, yes this monitor should be covered by a warranty, my advise is to return it to the vendor and ask for a replacement.
These things die like files as the saying goes. But HP are real good with warranty usually simply make contact with HP and ask them what to do, and be guided by them if the vendor isn't helpful.
Sep 10, 2011 | Computers & Internet
Hi! Ive bought an Asus LS246h today and it won't start. Ive checked all cables and Ive got power on the power plug. None of the lights at the monitor are working! Is my monitor defect?
Hello there,
It looks like you have a faulty monitor. Make sure the power is plugged in at the computer and a working all socket. Make sure that the Box on the power cord is connected properly. Make sure that the connections to the computer and secure and that the computer is turned on. If none of these things fix the monitor, I recommend returning it and getting it replace.
I hope this has helped! Thumbs up are much appreciated.
May 07, 2011 | ASUS LS246H Monitor
My hp monitor is totally black it was working last night. i tried to unplug and replug it in and it came on for a few seconds then went black again
A lot of time people have the impression that the monitor is not working when in fact the computer is not booting its lighting up but nothing else so its stays on a black screen.
One way to know is by opening your speakers or plugging head phones, if you hear windows open or any windows sound the problem is the screen.
You can also unplug the screen from the pc and turn the screen on most of the time the screen while show a disconnected warning on the screen if that comes up the computer is defective.
Oct 29, 2010 | HP Computers & Internet
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
Hi
Please see the following link
many available for fairly cheap prices
http://shop.ebay.com/sis.html?_kw=KDS+LCD+Monitor+17inch+17%22+k717+k+/+717+700p+/+700+p&_nkw=KDS+LCD+Monitor+17inch+17+k717+k+717+700p+700+p
I hope this has been useful
Mar 09, 2010 | KDS K717s 17" LCD Monitor
Hi, monitor is HP vs19c less than 2 yrs old. One
Your monitor probably has roasted capacitors. And your warranty is probably passed. Happens to a lot of different brands too. The capacitors are cheap, and not too hard to replace if you posess the soldering tools and skills. If you can't do it yourself, finding a shop to do the work can be tough, and may be pricey. Some opt to sell on ebay and just get another monitor.
Dec 20, 2009 | HP vs19 (Silver) 19" LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
After 15min the monitor cuts off. KDS k717. Iturn it off for a few min and turn it back on and it does it again
power converter/supply bad defect contact manufactuer and ask for warrenty replacement
Mar 13, 2009 | KDS K717s 17" LCD Monitor
I need a replacement power cord
Found one here:
http://acebargains.stores.yahoo.net/acpoadforwel.html
and ebay looks to have a few as well:
http://cgi.ebay.com/AC-power-adapter-Westinghouse-LCM-17V2-sl--LCD-monitor_W0QQitemZ360118562836QQcmdZViewItem
Hope this helps. You are right this far from a typical power supply cord. Most just need to the cord with a 3 hole female end that plugs straight in the monitor.
Mar 02, 2009 | Westinghouse Computers & Internet
Kds just two seconds
I have the sameproblem soI plugged in a HP 1702 after 2 days it started doing the same thing. I am using an old school kds with no problems.
Could it be a bug in the system with flat screens.
Jul 28, 2008 | KDS K717s 17" LCD Monitor
Monitor power cords are an industry standard, you can pick one up at your local electronics store such as radioshack,bestbuy,circuit city.
da51706.jpg $7.99 instore price, or can be order from radioshack.com, part number 61-2859
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Gateway FPD2275W LCD Monitor
KDS K717s 17" LCD Monitor Logo
231 people viewed this question
Top KDS Computers & Internet Experts
Gary Finch
Level 1 Expert
joecoolvette
joecoolvette
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
