Question about Gateway GT5468 Desktop PC
Dvd / cd rom not recognized on my computer list
Gateway gt5468 won t recognize the cd rom drive
  • 1 more comment
  • ntyankaitis Feb 28, 2009
    My dvdrw drive does shows up on the device manager list, and there is a yellow (!) triangle on it. I click (check for solutions) and it says it is loading for a second or two and then the message goes away and nothing happens. I have tried switching DVDrw drives out as well as cables, but the same thing happens. Help!
  • Anonymous Mar 26, 2014
    Windows 7
  • Anonymous Mar 29, 2014
    I just bought a new gateway dx series but I can not get the door to open to put DVD or CD in?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
1) Go to Control Panel. Open the System Icon.
2( Click on Hardware Tab, then click on Device Manager.
3) The device manager will list all of your hardware that is on your computer.If you see a yellow? mark oryellow ! mark next to your DVD/CD rom drive,simply click on it then click Repair. It also may tell you that it is not recognozied. Follow the directions.
4) If you do not see this in your Device Manager go to Add Hardware in your Control Panel which is next to your Add/Remove Programs icon. Click on Add Hardware and it will scan for all hardware.
** This should take care of your problem.If not then somehow the actual connection in your tower has come loose. If so you must open your tower and look for a loose wire going to your DVD/CD rom drive.
*** Please let me know if this corrects your problem.Simply email me(Phil) at: philw19642002@yahoo.com
Posted on Jan 01, 2009
  • Phillip Whisenant
    Phillip Whisenant Jan 03, 2009
    Glad to hear you resolved your problem. However you really didn't have to go to Best Buy (Geek Squad) the download is optainable on the web. Thanks anyway for your thoughts of sending it to me.
    Thanks Again & God Bless,
    Phil
CD ROM won't recognize CD's/DVD's
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Dec 13, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
T-20 does not recognize cdrom. When I check device for the drive, it has an !, I have uninstalled and reinstalled the driver, and it still won't recognize the D drive..HELP
Your problem seems the device it not detected properly or is not being assigned a drive letter. First try this, Right-click "My Computer" > "Manage" and then click on "Disk Management", you'll be able to see Cd/Dvd-Rom drive on the lists of available Disk Management snap-ins, right click on the Cd/Dvd-Rom and click "Change Drive Letter and Paths" or it could be "Assign Drive Letter and Paths", once you click it, another dialog box will open up, click "Change" and assign a drive letter from the lists (you'll see an option as a drop-down-list), click "Ok" and restart your computer. You will be able to see the Cd-Rom drive in the My Computer directory.
If this doesn't fix your problem, you need to check the connectors of the cd-rom, means you need to unmount it from the machine and clean the connectors on the cd-rom and on the computer.
It's also possible that the cd-rom itself is defective, in that case, your only solution is replacing with a new Drive.
Good Luck.
Thanks for using FixYa.
Aug 19, 2010 | IBM ThinkPad T20 2647 Notebook
Computer will not recognize external cd rom drive
Use the following link, scroll a little and click on Fix It
http://support.microsoft.com/kb/314060
Click Run in the File Download dialog box and follow the steps in the wizard
When completed restart the computer and check the CD/DVD drive
(you may need to run Fix It twice)
If it fails, there is a manual method to edit the registry. Let me know so that I can follow up further.
Mar 11, 2010 | Toshiba (PA3438U-1CD2) CD-RW/DVD-ROM...
Dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Feb 04, 2010 | Gateway 5200XL PC Desktop
Missing drivers for Gateway desktop DVD drive. manufacturer's website useless.
I recognize that you've previously visited Gateway's support site, but I recommend trying again at the follow page. You can choose your exact desktop from this list:
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10021&st=browse
You should be able to find the driver for your DVD drive there.
If not, you can open the computer case, find out what the manufacturer of the DVD-ROM is and go to their site to find the necessary driver.
Also, have you tried using the "Update Driver" utility in Windows? You can manage drivers from within the Computer Management console of Windows.
1. Right-click on My Computer and select Manage.
2. Then select Device Manager.
3. Expand CD/DVD-ROM drives.
4. Right-click the drive and select "Update Driver"
--Good luck!
Aug 01, 2009 | Computers & Internet
DVD/CD drive burns, spins, won't read DVDs or CDs
CD and DVD use different lasers. You appear to have a bad or out of adjustment laser. Replace the drive.
Mar 01, 2017 | Sony Computers & Internet
Worked in other computer in this Gateway Celeron 1.2gh it does not recognize that it has a cd or dvd in it. Running WinXP Pro with sp2, roxio 9 and Cyberlink PowerDVD6
If the pc isn't recognizing the hardware the main reason this happens is that you need to install the proper drivers.
Here's a link: Hope it helps
http://www.opendrivers.com/category/15/cd-rom-free-driver-download.html
Good Luck =)
May 24, 2009 | CyberDrive DVD-ROM DM-166D Internal DVD...
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
Gateway GT5468 Desktop PC Logo
300 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
