Question about GE (PSS26MSRSS) Side by Side Refrigerator
Frig and Freezer box not cooling - GE (PSS26MSRSS) Side by Side Refrigerator
  • packrdiane Jan 03, 2009
    Same problem, especially on the freezer side. I sometimes do hear a fan running.
  • Ken Bledsoe May 11, 2010
    When you open the freezer door do you hear a fan inside?
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ncxbnx
Posted on Sep 29, 2010
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
My frig is cold in the freezer but not in the frig are. What could be wrong?
heatman101
Apr 27, 2011 | Magic Chef Refrigerators
Water leaking from freezer box onto top self of frig. Has to be wiped once a day.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Mar 11, 2011 | Kenmore Refrigerators
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
Refrigerator is cold in the freezer, but the top of the frig is not cold. Is there are fan to cool the top part of the frig?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 05, 2010 | Amana ABB1927DE Bottom Freezer...
The freezer is icing up up and the frig is warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 08, 2010 | Frigidaire FRT17B3A Top Freezer...
Frig doesn't cool. Freezer works fine. freezer
You have solved your problem :D You need to get that fan blowing. The vast majority of the time that is all you need. Other times, there can be another part controlling the operation of the fan (ADC - Adaptive Defrost Control). Post the model number and I will see if you have one of these ADCs in your appliance :D
May 31, 2010 | Whirlpool Refrigerators
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirpool frig. freezer works frig doesn't
access to the evaporator fan is in the freezer behind the rear wall.
Feb 18, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
44 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
