Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Rail bows when door is all the way down - Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
  • odaat_95 Jan 01, 2009
    When I back off the down limit it doesn't close the door. It stops about an inch from closing. Thanks for answering though.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Back off the down limit.
Posted on Jan 01, 2009
  • Joseph Chapman
    Joseph Chapman Jan 02, 2009
    You seem to have turned the down limit too far. Sometimes they are very sensitive. Also, your "j" arm (the arm that connets the operator to the door) should be almost vertical when the door is in the down position and the curve part of the "j" should be monted about 2" below the top support (strut) on the door.
2 Suggested Answers
Door Tech
  • 98 Answers
SOURCE: Rail bows when door is closed
What you describe is common with those operators.
Posted on Jan 02, 2009
Moter makes a skeeking noise
Check the track rollers. Lube if dry.
Check the trolley, lube as needed.
Check the long lead screw the trolley follows, lube as needed with lube for that type of opener. If it is in the motor housing, is it time for a new opener?
I had an opener that drifted in adjustment, that would go beyond the closed position a little causing the rail to bow upwards a little once closed, putting strain on the gearing shaft bearings and wore them out. I was able to order a package with the pinion gear, drive gear and sprocket and bushings, including the pulley for the opposing end in one kit.
Cautions...
-Disengage the trolley from the belt, chain or lead screw.
-Unplug the power before opening any opener covers and servicing anything inside the unit.
-Readjust the open and close travel positions
May 21, 2016 | Building Materials
Arrow won't lay flat on the rail
Dangerous situation Contact Barnett lifetime warranty. DO NOT SHOOT THAT BOW. I Repair bows in Northwest Indiana. The Archery Clinic
Sep 15, 2013 | Barnett Crossbows Barnett Wildcat C5...
Door comes down and goes right back up. then the lite blinks 4 times with a click noise. the safety eyes also are not on
It sounds like you need to adjust your down limit switch and/or perhaps your motor force settings. If the limit switch is not in the sweet spot along the rail it can be triggering too soon or not in time. In your case it could be too far down the rail and thus not stopping/slowing the motor in time. Your door is then being pushed against the floor too hard. Your safety/return force is goes way over limit and tells the opener to go back. While closing your door look at your rail and if its bending when the door hits the ground, this is definitely happening. After finding the sweet spot for your down limit switch, you can readjust your return/safety force per your opener manual.
Jan 03, 2011 | Chamberlain 12HP Power Drive Chain Drive...
I just installed a new 'rack' to my Craftsman Garage door opener on the screw drive rail system. It now goes up and won't go down. How do I adjust the up / down limits to get it going?
You will need to release the door from the opener and then open the door manually and make a mark on the t-rail where the trolley is. Then remove the t-rail from the motor unit and manually run the rack to the mark on the t-rail. Now run the motor until it runs and stops in the up position. Reassemble all the pieces. This will get everything back into sync.
Feb 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My passenger window dropped down into the door, the motor of the automatic door still moves up and down How do I get the windown back on the automatic door opener
seems like the window fasteners came lose from the rail what needs to be done is to go inside the door and refasten the clips or pop the rail fasteners back into the window
Oct 04, 2009 | 2002 Jeep Grand Cherokee
Belt drive track arm bows up
YOU MAY NEED TO GET THE SPRING ON THE DOOR ADJUSTED.
WHEN AN OPENER IS INSTALLED THE SPRING SHOULD BE SET A LITTLE HEAVY. YOU WANT THE DOOR TO SLOWLY DRIFT CLOSED IF LEFT HALFWAY UP.
IT SOUNDS LIKE EITHER YOUR SPRING NEEDS ADJUSTMENT OR THE DOOR BINDS AT THE BOTTOM - HOW DOES IT WORK MANUALLY??
IF YOU CAN'T CLOSE IT WITH 3 FINGERS THE OPENER WILL HAVE TROUBLE.
YES THE CRAFTSMAN RAIL IS WEAK MAKING IT THAT MUCH MORE CRITICAL TO SET THE HEIGHT PER INSTRUCTIONS AND MAKE SURE THE DOOR WORKS EASILY,
HOPE THIS HELPS
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Bottom rail fit on 1500D door in 28" shower stall...
Mark, I'm having different problems with the same door. Try "filing" down the ends of the bottom rail, where it is contacting the curved corners. You might have to buy a metal file to accomplish this. Go heavy on the adhesive caulk on the underside of the bottom rail. Make sure the shower base is clean and dry. You might have to push down with your arms for several minutes to get the adhesive caulk to stick. Good luck, I have to go back to my folks this afternoon, because I can't get the door panel in w/o it scraping the top rail. Ugh.
Jan 22, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Jan 01, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door won't go down because of interference
IF YOU ARE TALKING ABOUT THE JOINTS IN THE RAIL THE TROLLEY TRAVELS ON THEY USSUALLY ONLY GET OUT OF ALIGNMENT WHEN THE BOLTS THAT HOLD THE SECTIONS TOGETHER ARE LOOSE.
Dec 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
212 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
