Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer too cold, but freezer keeps running
I have a freezer that just keeps running even though everything in it is hard as a rock. The temperature shows 10 degrees which is obviously incorrect. I had a tech look at once already, but he couldn't find anything.
  • 1 more comment
  • counttewfour Nov 29, 2007
    We have a KSCS25INSS - about 3 months old. An analogue thermometer placed inside the freezer side indicates -20 F. The LED readout on the for the freezer (blue display on the fridge side) reads anywhere between +35 and +70 depending on it's mood.
    The fridge temp.- thermostat does appear to be accurate and functioning well.
  • cl28270 Nov 12, 2008
    I have exactly the same problem-my unit is only 1 year old! Did changing the thermostat work?
  • Anonymous May 01, 2009
    freezer still running and food hard as a rock
Change thermostat
Posted on May 13, 2007
SOURCE:
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
I live in Winnipeg, Manitoba. I have an old Kenmore upright freezer. I would like to leave it in my unheated patio over the winter. Should I leave it plugged in, or can I unplug it and just watch the...
Leave it plugged in. It won't over freeze. If the outside air is cold then it won't need to run as much to bring down the temp-nature is doing that. So when the weather gets warm it will run to keep everything frozen. Hope this helps. Google burdfrenzy
Nov 25, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Oct 03, 2007 | Kenmore 50522 / 50524 Side by Side...
Freezer is over-freezing
most have 2 controls in the refrigerator side. 1 is a thermostat or cold control the other is a air damper. the damper allows the flow of air from the freezer to the freshfod side. if it is closed all the way you are keeping all the cold air in the freezer and that will make it colder. most cold controls monitor the air in the fresh food section and regulate the temp. and some controls are confusing and the damper actually works in the reverse of what you think. but if the unit is always running you may have a bad cold control and it is sensing the temp in the refrigerator side is not col enough, so it will continue to run until is can be satisfyed. check the control to make sure it is shutting of if you turn it up. if not I would replace it. I dont know how old the unit is but you also may have some electronics that control the temp to.
Aug 09, 2007 | Kenmore 57029 Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
633 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
