Home | Philips | 60P8342 60 in. Rear Projection Television | My hitachi 60SBX72B hav...
Philips 60P8342 60 in. Rear Projection Television
Problem for Philips 60P8342 60 in. Rear Projection Television
My hitachi 60SBX72B having picture convergence problem, how to fi
By mbp1946 on Jan 01, 2009
Three color beams are not aligned over each other. TV was fine for last 10 years. This problem started while we were watching TV.
Clarification Request
Posted by rlputnam on Apr 21, 2009
You have been a great help. I have discovered that I can buy the convergence chip and cooling oil for $100+. Now I need to know how difficult is it to replace the chip and change the oil? How long would it take the average guy and how likely is it that he would be successful? Thanks!! Rick
Best Solution
posted on Feb 15, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Philips Expert
Rating: 93%, 524 votes
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 14, 2009
Somewhat Helpful)
Usefulinfoor
Rank: Apprentice
Rating: 72%, 2 votes
What i have read alignment of tubes can drift over time. Should setting for realignment. You may enter Service Mode. Hope this helps you.
Was this helpful?
Yes
No
Solution #3
posted on May 17, 2009
Not Rated)
tom_dort
Rank: Apprentice
Rating: 0%, 0 votes
Seems like the convergence chips are the problem. The picture with the bow in the center of top and bottom matches my screen. Also my colors don't line up.
Was this helpful?
Yes
No
Popular Solutions for Philips 60P8342 60 in. Rear
Questions and Unsolved Problems for Philips 60P8342 60 in. Rear
Do you recommend Philips 60P8342 60 in. Rear Projection Television?
Answer
Answer
I have a 60P8342 projection tv. When I turn it on you can watch it for about 2hrs then it shuts... (More)
Answer
all the bright lights like sunlight,any reflecting lights give off a high glow dulling the rest of... (More)
Answer
I tried to look through your problems/solutions section but it isn't available. we have a phillips... (More)
Answer
Turned tv off with remote last evening and when tried to turn on this morning, on light did not come... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 60P8342 60 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
