Question about RCA D52W19 52" Rear Projection Television
Green lamp goes out within minutes of turning on tv
I have an RCA 52" Model, D52W20 about 4 years old, 2 weeks ago the green lamp went out and lights up only momentarily upon putting on the tv. I need some help in how to remove and replace this lamp if possible or perhaps there's something loose? Any advice or guidance would be greatly appreciated.
  • RCA Master
  • 5,138 Answers
Check CRT board the Video IC on it can be bad so you do not have to replace Tube be Very carefull when you remove CRT board from Neck of Green Tube so you do not Breck it. Check all 3 tubes make sure none of them are leaking out coolent fluid.
Posted on Jan 01, 2009
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
My rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
RCA 52in HDTV will not stay on
I would turn the circuit board over and check for clod solder joints and cracked solder, you will have to look close, my other sugestion would be to get a can of freeze and spay the different IC's and see if it stays on longer.
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WD-52327 52 in. Rear Projection DLP
I have a 2 year old Mitsubishi Rear Projection 52" model WD-52525. I recently experienced the same problem as you. My TV quit without any warning and the red lamp light came on. I bought a replacement lamp just like you did, did everything you did too, but it still didn't work either. Since it's past the 1 yr warranty (of course), I took it in to an authorized service center for an estimate. They determined the light engine failed and it will cost me $816.35 to repair. I already shelled out $240+ for a lamp, $48 for the repair estimate and I said "hell" no, I'm not going to fix it for another $800+ and bought a new TV. I'm writing a letter to Mitsubishi expressing my deep dissatisfaction (to put it mildly) with this faulty product and will be requesting reimbursement, which I probably won't get. I sincerely hope this is not the same problem your TV has, but if it is be prepared for a costly fix.
Aug 06, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
