Question about Emerson Fans Emerson MW8115SS Microwave Oven
Electical arcing (sounds - looks like something is being welded)
First occured when I was melting butter in a glass container. From behind the "screen" on the inside of the machine, came a bright light (electrical arcing) and a point on the screen began to glow and smoke.
Problem repeated
  • Emerson Fans Master
  • 9,098 Answers
(Sorry, but your subject line got cut off.)
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
If you need further help, please reply back with your brand and model number so we can help you.
Posted on Jan 03, 2009
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
Dec 15, 2015 | Microwave Ovens
My Bosch Micro HMB405 started sparking/arcing with a burning smell. I had an empty plate in there. Was trying to warm a clear glass dinner plate. Did I kill the magnatron by putting an empty plate in the...
You may have killed the magnetron but you may not have either. If you can take that cover plate off, you may find that there is grease build up behind it and that needs to be cleaned off. Grease can build up there without you even realizing it and after a while it can catch fire from the heat created by the magnetron. You should never put any empty plate or container in a microwave because the magnetron needs to have something for the waves to hit. Hope this helps.
Mar 25, 2015 | Bosch Microwave Ovens
Sharp R959SLMA
Could be arcing around HV transformer or even an HV wire, Sometimes an insulator on a capacitor will get old, dusty or breakdown and arc between the terminals. Have you ran this with the cover off to see if you can see any visual arcing??? If it cooks sure sounds like it is probably not the mag. Something supplying power to the mag arcing to ground I would expect.
Aug 18, 2017 | Sharp R959SLMA 900 Watts Convection /...
Can you oil or butter in with popaire 2,
(BUTTER chamber thing) The little rectangular scooper-looking thing on the slope of the top is where you can put a chunk of butter that will melt from the hot air and drizzle into the popcorn popper as the popcorn is popping. My dad said you cant use oil in it
May 02, 2011 | Microwave Ovens
Maytag Over The Range Microwave: Melted glass turntable, rollers
Considering the melting pooint of glass ...
Normally, microwave travels around round surfaces (Look at the B-1 for example) If you put flat metal in a microwave, you will create sparks ... lots of em. Is it possible you have something going on with one of the wheels ... like a piece of tin foil?
At a minimum, I think id be inspecting everything inside very carefully and then give it a good cleaning.
You might want a pro in your area tale a look at this as well.
Oct 05, 2009 | Maytag MMV4205 Microwave Oven
Panasonic MW- Arcing
You're on the right track. That panel is the waveguide cover.
This is usually due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover in the waveguide just out of sight.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
To order Panasonic parts see
Nov 07, 2007 | Panasonic NN-T990SA Microwave Oven
It sounds like the magnetron is overheating and the magnetron-mounted thermostat is tripping.
This can happen if the internal cooling fan is not running - do you feel air strongly coming out the back or other vent?
If it has grease or other filters, be sure they are clean and not blocked.
Otherwise, the magnetron may be failing. Please post back once you've looked this over if you need more help.
Nov 02, 2007 | Magic Chef CMV1000B Microwave Oven
Crackling/sizzling sound
If you're hearing a crackling noise and don't see any sparks, you may have a magnetron that is arcing inside the waveguide. Once this arcing occurs, in some cases, replacing the magnetron may not be enough to fix the problem. There was also a noted problem with some models where the stirrer motor shaft inside the waveguide would arc when the magnetron was energized. This too, caused damage inside the waveguide. If the internal walls of the waveguide become damaged it cannot be repaired and the unit must be scrapped. The waveguide has a special coating to help propagate waves of RF energy. If the walls are damaged due to arcing this special coating gets burned off and will continue to arc even if a new magnetron is installed. This will eventually lead to magnetron failure and potentially cause a fire inside the oven. I would think seriously about looking into another unit if any of this may be occurring in your oven. Better to play it safe, especially with small children. I hope you find this advice helpful. PS A new magnetron can run as high as $250.
Jul 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Fans Emerson MW8115SS Microwave Oven Logo
153 people viewed this question
Top Emerson Fans Microwave Ovens Experts
William Miller
William Miller
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
