Upstairs unit My gas heater will come on when you turn it on and fire up and run but before the cycle is complete it shuts off and will not come on it's own.You can turn it off and then back on and it will come on briefly and do the same thing.I have changed the thumostat to a digital one did not help so I replaced the limit sensor nothing ,got any advise for me?
  • 189 Answers
Clean the flame sensor....
Posted on Mar 08, 2009
Pilot lights up but would not fire up into heating, I have brivis buffalo 85
This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
If the pilot turns on and the gas ignites, then shortly after the unit shuts off, chances are this is your blower motor. It is not starting up, then the heat limit is reached in your unit and the safety shuts it off.
Mar 02, 2011 | Honeywell Programmable Thermostat Heater
Heil heating unit ran out of lp will no restart fan runs no fire up
if you ran out of lp you my need to purge the line. shut off power and crack gas line as close to gas valve as you can.try a 5 sec. count. reconnent and check connenction with soapy water for leaks. if none return power and turn t stat up. if it cycles and doesn't lite turn t stat down and then recycle may take 2-3 times. the fan runs on a timer. when the t stat is in demand the fan will run by turning the t stat down below room temp the fan will shut off.
Jan 29, 2011 | Heating & Cooling
I have the rheem pronto in one of my rentals and the water is cold all the time. Help!!!
3 items possibly:# 1) has that gas company turned off the gas lately to do some work?,and then re-fired the water heater after the work was completed? if so,check the temperature setting on the unit,as most gas companies upon re-start of gas appliances on their line will just set them to LOW,so as not to have an insurance issue with a scalding problem(from someone setting it TOO HIGH) if set above LOW temperature./ # 2) it could be limed up in the bottom and not have the capacity anymore to heat the full capacity of the unit due to this issue & needs shutting down and draining and a fresh re-fill. / #3) if the unit won't fire after the pilot has been lit(held down to keep lit) and then turned to a heat setting from pilot,you can have a defective thermocouple temperature sensor in the flame not letting the gas valve open fully to heat the unit
Jan 25, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Heater starts and runs for several minutes and then turns off
Since the unit runs for a couple minutes, I would first check for proper water flow. Find the pressure switch. It is usually round with two wire terminals and a copper/metal tube attached to it. With the wires attached, use a jumper wire to bypass the switch. If it runs longer check for flow problems.. (WARNING don't jump the switch for too long!!! Just enough time to see if the run cycle improves). Clean all the skimmers baskets, pump basket, backwash the filter (if a cartridge filter clean the filters). Try firing the heater again. If it still shuts down, replace the pressure switch. I never recommend adjusting it. Adjusting it too low can damage your heater and/or cause injury.
Jul 21, 2010 | Hayward 250K BTU NATURAL GAS POOL HEATER...
Pentair matertemp 400,000 BTU heater cycles on & off
My pentair matertemp 400,000 BTU natural gas heater cycles on and off before reaching desired temperature. I completely cleaned the DE filter and flow should not be an issue. When running the spa the pressure is 25. When running the cleaning system (polaris pop ups) the pressure is 30. Burner fires for 80 seconds then shuts off, reignites after 53 ceconds.Any tips on what might be the issue with the heater
Apr 04, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Fire and Heaters producing soot.
no its not gas it sounds like fumes get them checked over asap the localgas company will check them out for you
Jan 10, 2010 | Cozy (W352E) Heater
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
have service completed
Oct 24, 2008 | Rheem Water Heaters
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
