Question about Panasonic KX-TG5632 Phone
Access voicemail from another line while away from home
How do I access my voicemail from my home phone (Panasonic) while I am away from home? Can I call my home number while away from home and enter a code so as to access my voicemail?
Also, can I get a copy of the phone manual online or by fax or by mail?
My model #: KX-TG6071B
Thanks and Happy New Year.
Brian
  • Anonymous Mar 24, 2014
    How do I get the access code in order to check messages on this phone when I am away from home?
The previous solution only works for older machines. I have the same Panasonic model and this works every time.
On your handset, hit the top center button(menu). Touch the arrow down button 7 times. Should say "Initial settings". Hit top right button on handset (display shows this is now the "select" key). Display now shows "Set Answering". Hit top right button again ( select key). Display now reads "Ring Count". Hit arrow down button 2 times. Display now reads "Remote Code". Hit select key again and enter your desired 2 digit remote code. Hit "Off" key. When you call the answering machine from the road, simply enter those same digits. Piece of cake. Enjoy.
Posted on Jan 10, 2009
    Problem Solver:
  • 9 Answers
Dial your home number, and when the answering machine picks up, enter the code (found on the bottom of the machine, in most cases).
You should then hear your options. each phone is different, but generally, this is the process.
Posted on Jan 01, 2009
  • mrfixit64857
    mrfixit64857 Jan 01, 2009
    Here is your manual, by the way!
    http://phone.manualsonline.com/mdownload...
Have panasonic phone and dont have a code..not on the bottom of machine...
KXTG1031S....leaving at 2 in morning need help...manual will not show up on my computer
Posted on Jun 09, 2010
Lg3 won't let me enter password to get voicemail. Can't get to pad to enter numbers
you should have an icon on screen that allows you to open the key pad
Jan 06, 2015 | Cell Phones
Voicemail
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voicemail access code and press [SAVE].
Apr 22, 2014 | Panasonic KX-TG4753B DECT 6.0 Plus...
How do I access messages when away from home
Hi Helen,
Yes you can access your messages when you are away from home. See attached manual pg 41 for remote access operation.
Call you number from remote phone,when the greeting starts enter your access code ( if you have set one already otherwise use default 11.) The your phone will play the new messages
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.PDF
Nov 03, 2011 | Panasonic KX-TG5632 Phone
How to check voicemail messages
I assume you mean voicemail messages taken by voicemail service on your telephone line, the ones indicated by a flashing "voicemail" indicator on the phone. You may need to contact your service provider as not all systems are the same, but here's how it usually works. From your home phone, dial your own number so that the voicemail answers. Press the "*" button and you'll be prompted to enter your passcode. (The default passcode is usually the last 4 digits of your phone number, and you enter a new one when you go through mailbox setup.) Once you've entered the passcode and are in the voicemail system, voice prompts guide you through how to access messages and make setup changes. To process is usually the same to check your messages when you're away, although some service providers may give you a different access number to call. Again, check with your service provider for all the details if your system is different.
Sep 14, 2011 | Vtech 5.8GHz Analog Cordless Phone
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How can I remotely change my outgoing message on my panasonic cordless home phone?
It will depend on the exact model of your phone, but generally you can access the message area by dialing your home phone, waiting until it goes to voicemail, and pressing the # key any time during the voicemail message. You'll be prompted to enter your PIN and will then be able to change any settings you need to. If this doesn't work, please reply with your phone's model and we can get it figured out. Good luck.
Mar 04, 2011 | Panasonic Cell Phones
KX-TG1031B how do you retrieve messages at a remote location?
it's called remote operation. Press "MENU", then "number sign" and enter a 3-digit code of your choosing. Press "SAVE" and then "OFF" When you away from home, dial your phone number and after the greeting message starts, enter your 3-digit remote access code.
Dec 21, 2010 | Panasonic Lands Phones
How to access my voicemailbox from a different extension at the office?. Also, is it possible to access it from home? (Mitel 5212)
Assuming you are using the Embedded Voicemail... Dial the Voicemail access code (same number you dial from your phone). When prompted to enter the other phone's password, dial *. You will be prompted to enter your mailbox number, followed by your passcode.
Sep 14, 2010 | Mitel 5212 IP Phone
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Nov 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG5632 Phone Logo
2,193 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
