Question about Mitsubishi WS-73411 73" Rear Projection Television
No HD 1080i
My Mitsubishi 73411 works fine except for the HD portion. I can plug a DVD player into the DTV inputs and run 480i and 480p. But when I plug in the X-Box 360 and put it in 1080i mode the picture acts like it is out of sync. The picture looks like it is in normal mode (narrow) and overlapping itself 3 times. I can read the TV generated text in the corner and it says "1080i" but the picture is scrambled. Any hints as to where to start troubleshooting? John
  • John Homewood May 21, 2007
    Yes, the xbox is in HD mode and the TV automaticaly selects the correct operating mode. As I stated, the small printing that is in the upper left corner of the TV screen when the input is changed can be read inspite of the lack of sync. It clearly says that the input is DTV and it is in 1080i mode. So the TV thinks it is running 1080i but something is wrong with either the horizontal or vertical sync frequency. I am not sure which.
    I can see on the schematic that there are several lines marked as being 480p/1080i in the sync signal area but I can't find anywhere that there is any signal that selects between 480p and 1080i. I suuspect that the problem in in the horizontal sweep frequency since the vertical sweep frequency for 480p and 1080i is almost the same and the 480p works fine.
    President:
  • 2,961 Answers
Have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
Posted on May 21, 2007
  • andrew pester
    andrew pester May 21, 2007
    if you get in touch with techman live and for free i'm sure he will be better qualified than me on the technical side of tv's, he's online now
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
My television only puts out a pic in 480. The 720 and 1080 are not working. Getting sound no picture
No input on a WS-55511 is capable of 720p . Inputs COMP1 and COMP2 ONLY accept 480i/480p . Input DTV accepts 480i/p and 1080i . When using Input DTV with a component connection(YPbPr) and you get a green or no picture then you will need to navigate the menus and setup input DTV for YPbPr instead of RGB.
Oct 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
1080i
grab your TV remote and go to setup. check your input settigs and change them from RBG.
Aug 30, 2008 | Mitsubishi WS-65413 65" Rear Projection...
HD channles
Hi Scan 1080: Enables you to receive the 1080i, 720p, 480p and 480i digital TV formats. By using the VIDEO 5/6 IN jacks, you can connect a DTV (digital television) receiver to view DTV programs. q DRC Multi-Function: Unlike conventional line doublers, the DRC feature doubles vertical and horizontal lines, resulting in four times the density for quality sources such as DVD, Satellite and Digital camcorder. q CineMotion: Using the 2-3 Pull-Down technology, the CineMotion feature allows you to obtain a smooth picture movement when playing back movies or other video sources on film. q Twin View: Using Multi-Image Driver (MID-X), Twin View allows you to watch two programs side by side with the ability to zoom in one picture and listen to selected window. You can watch pictures from two different sources (1080i, 720p, 480p or 480i) simultaneously. q 16:9 Enhancement: Vertical Compression technology that maximizes picture resolution on “anamorphic” or “enhanced for wide screen” sources, including selected DVDs. q Steady Sound: Equalizes volume levels so there is consistent output between programs and commercials. q Parental Control: V-Chip technology allows parents to block unsuitable programming for younger viewers. q Component Video Inputs: Offers the best video quality for DVD (480p, 480i) and Digital Set-top box (1080i, 720p, 480p, 480i) connections. q S-VIDEO Inputs: Provides a high-quality image for connected equipment. q Favorite Channel Preview: Preview up to eight favorite channels
Jun 02, 2008 | Sony KP-61HS20 TV
Mitsubishi WD-62525 Input 480i
it is just saying what input you have it on and what level of hd your getting (480i 480p 720i 780p 1080i 1080p)
Apr 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
HDTV comes up green
there is a setting in the menu under setup i believe it is called "LABEL VIDEO INPUTS". check you owners manual. you need to make sure that the DTV input is set to YPbPr NOT RGB.
Feb 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WS-65869 tv
You should have everything you need. I really don't think you have to order anything. Make sure you have whatever set top box you are hooking up to TV on the correct mode or setting... 1080i 720P 480P 480i etc....If you have any other questions... email me back or hopefully this was enough to get you up and running. Good luck and Happy Holidays....Jay
Dec 28, 2007 | Mitsubishi WS-65311 65" Rear Projection...
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Apple tv
The component 1 and component 2 inputs only go to 480i and 480p. The Apple TV must be plugged into the DTV input which will accept a 1080i signal.
Aug 18, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-73411 73" Rear Projection Television Logo
174 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
