Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
I have a nikon d40x with a problem with the 18-55 mm lens it not working in autofocus
  • 7 more comments
  • mauroperezmp Jan 06, 2009
    the lens switch is A
  • rurude2 Jan 21, 2009
    I have 2 autofocus and two manual lenses for my D40. The two autofocus lens will not work unless set to manual. It just started happening and I've had the camera and lenses for over a year. Is it just a pin stuck (I admit I have no idea how the autofocus works) on the camera itself or something in the programming. I admit I change my settings quite often to experiment.
  • rickandchris Feb 04, 2009
    When taking pictures, the auto focus feature doesn't work. This is a recent issue. Is there a recall or a way to get this fixed?
  • webfish Mar 22, 2009
    I have a similar problem. Nikon D40x with 18-55 lens. The lens just stopped autofocussing. It does work fine in Manual focus.
    I can confirm that the lens is locked in place properly and is set to AF. My other kit lens works perfectly in AF so this is clearly an issue with the lens itself I'm afraid. And my warranty has just run out !
    Looks like a design-fault judging by the number of posts I have found on this and other sites with EXACTLY the same symptoms
  • Anonymous Mar 29, 2009
    Yep, same lense, same problem, just stopped working today. bthe 55-200 works fine.
    Anyone know what Nikon is doing about it?
  • madamo Apr 01, 2009
    Same issue here. Doesn't seem that anyone has a solution. Basically, autofocus just stopped working one day. Switching the camera settings to manual and then back to auto sometimes gets it to work temporarily (for a few snaps at least). Otherwise no joy.
  • paparazzimam Apr 08, 2009
    For awhile my AF on the 18-55mm would give me problems, but eventually work. Now it doesn't work at all. My other lenses work just fine. I have both the D40x and the D300 and it doesn't work on either camera now. Manual works just fine.
  • Timm Chapman
    Timm Chapman May 11, 2010
    The D40x only autofocuses with the latest AF-S and old professional AF-I lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x.
    Is your lens an AF-S or AF-I lens?
  • Timm Chapman
    Is the lens switch set to MA or M?
  • 149 Answers
Problem with lens sencer replace it
Posted on Oct 06, 2009
D40
Posted on Jun 18, 2009
3 Suggested Answers
SOURCE: Sigma 18 -200 lens with D40x
This lens is NOT compatible as the body doesn't have a motor . £200 wasted
Posted on Jun 09, 2008
  • 146 Answers
SOURCE: Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Posted on Jul 04, 2009
Wife dropped nikon d40x on concrete...will only shoot on manual. Lens will not autofocus.
Lens motor(inside the lens) could be damaged already. The D40x focusing system is dependent on the lens, just like any other Nikon Dx camera except for the ones that has built-in motor to its body, e.g. D90, D7000. Try a different lens, most likely it should work
Jun 17, 2011 | Nikon D40x Digital Camera
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
Apr 14, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
Oct 14, 2009 | Sigma 70-300mm f/4-5.6 DG Lens
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
Jul 14, 2009 | Nikon D40x Digital Camera
No autofocus
We tried the same lens on another Nikon (D90) and auto focus did not work.
We mounted a new set of lens on the original D40x, and it worked.
Turns out the 2 year Nikon lens (18mm-135mm) was bad. Nikon lens have a 5 year warrantee. The lens will be sent back to Nikon with no service or shipping charge.
Thanks,
K
Dec 08, 2008 | Nikon D40x Digital Camera
How to set up 50 mm lenst for wedding photos .. and flash
Sorry this is too late, perhaps it will be useful to others. I hope you used a different lens for the wedding!
You can't use the 50mm 1.8 lens on the D40x unless you focus manually. This is because the D40x only supports autofocus with AF-S and AF-I lenses. The focus motor and drive mechanism for other AF lenses was omitted to make the camera smaller, lighter and cheaper.
Aug 14, 2008 | Nikon D40x Digital Camera
Jun 08, 2008 | Sigma 18-200mm f/3.5-6.3 for Nikon
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
266 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
