Question about Philips TP2784C TV
Need Unlock channels
Inherited a Philips/Magnavox Smart Series PinP model # TP2784 c101. Some channels are locked and don't know how to unlock. Don't know current access code either. Tried "0000" and no go. How do I unlock these channels?
  • Anonymous Jan 30, 2009
    i also received a tv as a gift and the channels are locked, i'm pissed!!
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Posted on May 18, 2009
Is there an 800 number I can call o get the factory setting for the smart series Philips magnavox tv? It was manufactured in August of 2003.
Try this number- the unit may have a defect in it and may need repair- you don't say what is wrong with it.
http://www.support.magnavox.com/html/index_us_en.html
Aug 09, 2012 | Philips Remanufactured Magnavox...
Philips Magnavox 2783 c101 - will not auto program tv channels
Ya what you got to do is Grab your tv, and throw it out your window. Garbage tv with built in problems made to be fixed. I had the same tv and i had many problems with it before. Just buy a new one boss.
Feb 17, 2010 | Philips Televison & Video
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
Our Philips Magnavox Smart Series TV Shuts Off
It is possible it could be a switch but this is usually after extensive use. If it does the same with the remote control chances are it's not the switch. These sets had problems with the vertical circuit as well. I've fixed a lot of these with vertical problems. It should not run but about $80-$100 to repair if it is a vertical problem. These sets have a lot of safety cicuits as well so it could be a horizontal circuit problem as well or power supply. Kind of hard to say without a good troubleshooting. Thanks
Nov 01, 2009 | Televison & Video
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Jan 30, 2009 | Philips TP2784C TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Magnovax tl712 c107 model #
Get a universal remote or go online and order a replacement original remote for your model. Then use the remote to enter the menu, unlock any child locks, make sure the set is in standard cable mode and do an autoprogram.
Aug 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips TP2784C TV Logo
650 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
