Playstation 3 not working with older model Pioneer AV receiver
I have an older-model Pioneer AV receiver, bought in 2003. It is, i believe, this model: c. My question is this: i'm attempting to hook up a Playstation 3 through this receiver, using the component input on the back, and it simply will not show a picture. Using a standard dvd player, or my TiVo, it works fine, but PS3 will not show up. Is this model capable of accepting a PS3?
  • 151 Answers
If you have set the component output on the ps3 for high def,ie 720p or 1080i and do not get a picture it sounds like the component input is not high def enabled on your amp,change the setting on ps3 to standard 576 output,or put picture into tv then sound into amp if you want to run 720p or 1080i.
Hope this helps.
CABLE GUY.
Posted on Jan 06, 2009
I bought a used Pioneer VSX 50 receiver and it did not come with the remote My old remote is not pairing with it. How do I get them to work together?
Hi Pamela,
if the old remote is not for the same make and is not one of those multi remotes that can now be bought then it will not work with the pioneer VSX or if it is from another Pioneer VSX then it may need to have the code re entered by Pioneer.
I would suggest to go to a shop that sels equipment of the same kind and ask for their advice and also whether they do multi controllers that would work, a shop such as Maplin (if you have a Maplin store where you live as they can be very helpful with such problems).
GOOD LUCK.
Feb 06, 2015 | Pioneer Elite Vsx 50 Av network receiver
Tip
Pioneer AVHP900DVD Manual Download
Download Pioneer AVH-P900DVD DVD AV Receiver Manual
Would you like to review the features of the Pioneer AVH-P900DVD DVD AV Receiver?
Have you lost your Pioneer AVH-P900DVD DVD AV Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Pioneer AVH-P900DVD DVD AV Receiver Users Guide?
Follow this link (& click FREE) to download a pdf version of the Pioneer AVH-P900DVD DVD AV Receiver documentation.
I hope that helps.
___________________________________________
on Jun 16, 2010 | Car Audio & Video
I've just bought the pioneer vsx 921 receiver with
The company's advertisement says it all. The company has mentioned the receiver as "Industry's First AV Receiver Designed for iPad". So it cannot compared with TV.
May 05, 2012 | Pioneer Audio Players & Recorders
Dear Sirs, I have a Pioneer AV Receiver model VSX-817 and is connected to Monitor Audio Speakers (Fronts: BR5, Center: BR-LCR, Rears: BR1), Sub: MS309 (Mordaunt Short). I have connected each front...
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
Apr 10, 2011 | Pioneer VSX-817-S
I have a Pioneer VSX-D411 and there is dsp ng flashing, what is it
http://www.retrevo.com/support/Pioneer-VSX-D411-Receivers-manual/id/385ci976/t/2/
I believe it's trying to tell you something is wrong with its digital sound processing.
This was the best source I could find on it:
http://www.avforums.com/forums/av-amplifiers-receivers/381823-problem-pio-vsx811s-no-sound-display-says-dsp-ng.html
If you switch it to satereo / direct and the light goes out I'd say that would clinch it.
Jan 15, 2011 | Pioneer VSX-D411 Receiver
I have a Pioneer reciever that does not have a hdmi input, also There is 1 optical input on it that my cable box is hooked up to. I have not opened the ps3 yet because I'm not sure how to get the sound to...
ps3 comes with an av jack set as well as hdmi. now you can use the hdmi to the TV and run audio out from the TV to the receiver and that should work but if you don't have audio out on the TV then you need to go get the av cable
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
Playstation 2 and 3 won't work on Sylvania 6432TE tv.
If you are using the Yellow, Red and White cables I believe you have to put your tv into AV mode. There should be a button the the remote or sometimes there is one on the tv
Mar 30, 2009 | Sony PlayStation® 3 (80GB) Console
Pioneer head unit plays in accesory mode, but not when vehicle is fully started
he tapped into starter wire instead of accessory. Remove radio and verify the switched power (red) wire is properly hooked up to an accessory wire that stays on after vehicle is started.
I believe the wire is white/black behind the radio. Check with a voltmeter to be sure.
http://www.the12volt.com/installbay/stereodetail/967.html
for the wire codes to that vehicle.
Oct 18, 2008 | Pioneer DEH-P3700MP CD Player
Pioneer VSX-D903S
just try prologic mode no tv uses 3 ch nomore ok and turn on ch a speakers only
Jan 29, 2008 | Pioneer VSX-D908S Receiver
384 people viewed this question
 Grubhead
Grubhead
