Question about Motorola Mobility RAZR V3
Blue tooth LED indicator
My motorazr V3's blue tooth indicator is turned on and does not turn off even when I selected POWER OFF from >connection>bluetooth>Power. I dont even see the blue tooth indicator on the LCD but I donno why the LED is permanently on. I think it is wasting my battery life. So please help me in this regard.
  • stockman0010 Jun 10, 2008
    Scholar:
  • 91 Answers
Try going to back to your bluetooth settings and making sure you phones visibility or "find me" mode is turned off. This is a good idea anyway cause anyone can find your phone. Then consider most people don't change their passwords so hacking into your phone and reading your texts and looking at your pictures and even trade things back and forth from their phone to yours!!!
Posted on May 13, 2007
Unlock code motorazr v3
Hi,you can try Theunlockspot to get unlock code for your Motorola Motorazr v3 and get it unlocked safely..
Dec 27, 2011 | Motorola Cell Phones
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
How to pair Motorolla 550
Please allow me to help you with you Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue tooth on your phone.
2. The phone should find the Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using Fixya.com "We have a solutions for everything"
I hope this solution was VERY HELPFUL!
Have a Great day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 29, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Hi wat is the shortcut to turning the blue tooth
hey brian
in this model there is no short cut for blue tooth as such but you can set a short cut by personalising your short cut keys like your joystick keys or even your selection keys.
hope it helps
Oct 03, 2010 | Sony Ericsson W350A Cell Phone
Why does my phone I keep getting blue tooth link busy
turn the blue tooth offf and back on again..make sure no one is linking up with your phone.
Jun 12, 2010 | Motorola Mobility RAZR V3
My Bluetooth set is plugged in but will not show up to add
Try to put your headset in pairing mode first. Press and hold the K1 button for some 8 seconds, until the indicator led is rapidly flashing alternately in red and blue. Then, make your PC's bluetooth application search for new devices. Your headset should appear. Select it make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done just once. After any 2 devices are paired, they should connect to each other just by being next to each other (provided their bluetooth radios are turned on, of course). Othewise, a simple press on the button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 28, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Motorola blue tooth
No problem, First you need to turn blue tooth on in your phone, menu>settings>bluetooth(sometimes it's connection>enable bluetooth. Then you have to tell your phone to search for a device I think that's under handsfree in the bluetooth menu. To put tell your headset to look for the phone make sure it's off. Then press and hold the power key until it starts flashing repeatedly, (if your headset has a flip mic you will have to flip it open as you are holding power) The trick is putting both the phone and headet into pairing at the same time. the phone should find the headet, you need select and it will ask you for a pass code, the pass code is 0000 . Hit connect and you are good to go. Good luck, if you need more details let me know what model headset and what model RZR. (V3, V3M,V3XX) L8R
Sep 17, 2007 | Cell Phones
Motorola Mobility RAZR V3 Logo
195 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
