Question about Epson Stylus CX3800 Printer
My printer will not print
It comes on but when I hit print it will not do anything.Ichecked the cables and the paper
    Problem Solver:
  • 10 Answers
Do you get any kind of error messages i.e. failure to print document or communication error? If you were able to print before, this might have something to do with pending documents on your printer driver. Try to do the following:
click start -> control panel -> printers & faxes (windows xp) / printers (windows vista)
look for your printer icon and check what's the status that would be found underneath the name. It should indicate a number (which is supposed to be 0, meaning no documents on queue) and below that should be ready. You may right click the icon and click "Cancel all documents" if there's an option for that and/or right click again for the "Use printer online" option. Let me know if you're still having troubles.
Posted on Jan 03, 2009
My Canon Pixma MX882 is not printing though lots of ink. Paper goes through when I press print on my PC but nothing is printed
Print a test sheet to see if the printer is OK. If tthe sheet prints fine has this printer worked on this computer before? Did you change anything or update anything? You may have the wrong driver installed or the cable could be defective if it has worked before.
Feb 02, 2015 | Canon PIXMA Office Equipment & Supplies
Message says no paper in front tray. Paper is where I've always put it in back. Won't print.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Nov 20, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I cleared the paper jam and hit "OK," but it still says there is a paper jam. I have blown out any bits of paper and dust and replaced the door and it still gives me the error. When I press "OK" the...
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Paper will not automatically print
check the settings on the printer and see what is set when it come to print from what trays? If the does not work, reset the printer by holding down the go button or on some printers its the ready button while powering it on and it will reset.
Jan 06, 2010 | HP P2035N LaserJet Monochrome Printer
My HP all in one C4400 printer is not working correctly. I hit print and it feeds the paper through without printing anything on it.
Try printing from another application and see if you get the same result. For example, if you are trying to print out of Word, try Notepad or MS Paint.
If so, check and make sure the ink cartridges and/or print heads are installed properly. Has the printer ever worked?
Hope this helps!
May 19, 2009 | HP Photosmart C4180 All-In-One InkJet...
Can't print with my hp deskjet d2560
unplug both your data cable and power cable from printer. log off and log on the system. first try with test page printing.
May 09, 2009 | HP DeskJet D2560 InkJet Printer
I can send faxes but I cant recieve any.
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
