Question about Panasonic TH-50PX75U Plasma HDTV
Video mode We have the above tv, and have tried to hook up a WII, and cannot get it into video mode HELP
I have the same TV and it is connected to the Video 1 ports on the back of the TV. As long as the TV input is set to Video 1 (or whatever you've renamed it to), it works perfectly. Good luck!
Posted on Jan 10, 2009
Specific info re hooking up Wii, no instructional manual. What is specifically needed to play the games?
To play the game you need to hook up three main things.
  • First plug in the RCA cables (red, yellow, white) to its corresponding jack on the wii and colors on the TV
  • Then plug in the sensor bar into the wii and place it either above or below the TV
  • Lastly hook up the power into the wii and the power outlet.
Power it up and play!
Jul 03, 2011 | Nintendo Wii Console
I have a 32" flatscreen
Different video signals use different connections ...and we are speaking ONLY the video(NOT including the audio connections)
  • Composite Video (typically colored Yellow) uses 1 RCA connection on your TV
  • Svideo (uses 1 svideo connector on your TV) a circular connector with 4 pins in it
  • Component Video (typically colored Red/Green/Blue) uses 3 RCA connections on your TV
These are the common analog video signals....You cannot mix and match these and plug a composite (Sometimes called AV in menus) into component etc
If both your sources (wii/DVD) you want to use a component signal to your TV (which BTW is the best quality of the 3 I listed) you will need 2 component inputs on your TV
OR
run it through a high end receiver (that will act as your switcher)
OR
buy a small stand alone switcher, something like: http://www.amazon.com/4X1-HD-Component-Av-Selector/dp/B000BVIBGI/ref=pd_sim_sbs_e_4
settle for a lower quality DVD signal and use the Composite video out (yellow jack) into the Composite Video In on the TV and use the component for wii
I hope this helps,
Magoo
Mar 10, 2011 | LG 32LG30 32 in. LCD HDTV
I hooked up my wii to my samsung tv and the tv does not find the input. I tried two different input areas on the back of the tv and no luck.
The remote should have a button labeled 'Input' or 'TV/AV' or something similar, this cycles the TV through each of its input modes (DVI, HDMI, RCA, Component, etc)...as you click to each one wait several seconds as the change over usually takes a couple seconds.
If this does not work verify cable attached properly. Im assuming that your Wii is working fine on another TV and so it not sending a video signal is not the issue?
Feb 19, 2011 | Nintendo Wii Console
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
My component cable is not showing any video.
it is a a/v hook up not a component hook up
try that like av1 av2 av3
should work a lot better
ron
Aug 29, 2009 | Sony KDE-42XS955 42 in. Plasma HDTV
Hooking WII to TV
check your using the correct AV channel for the connection. Try another input connector eg Scart
Jan 20, 2009 | Nintendo Wii Console
Can't get my new wii to work
Hello.
Most likely it is not your console. Depending on what type of TV it is there may be many different inputs in the back. My HDTV has 5! It can get confusing. If you have it connected directly to the TV, note which ports the cables are plugged into, then make sure the TV is in the correct output mode. Ex...cables are hooked to Video 1 in, set TV to Video 1 output. Now if you are hooked up through a DVD or VCR player it could be different. If you are hooked up to your VCR and the VCR is hooked up to the TV, the VCR would need to be powered on also. It would be the same for a DVD player. I really hope this helps you. The Wii is very fun!
I wish you much luck. If you have any more questions, please do not hesitate to click on my "Ask Me" button.
Thank you.
Aug 01, 2008 | Nintendo Wii Console
Hook up the Wii
If you have the remote for the TV, it should have an input button on it that would change the video mode. If you have a universal remote, often the tv/vcr button will do that function on the newer model TVs.
Good Luck
May 22, 2008 | Sanyo DS31590 31" TV
Panasonic TH-50PX75U Plasma HDTV Logo
83 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
