Question about Biostar NF325-A7 Motherboard
XP install Just about anyone can install "Windows XP Home OS." My delimma, I conduct the initial install "press any key to continue" ie: requested boot from CDROM, self supported generic drivers, acquired HDD assignment, Format, and so on. Now after the very first reboot/POST the OS request "boot from CD" again. If I do not answer "press any key" then I am told that "there was an error starting OS." I thought the OS was suppose to go one to the first windows screen w/ estimated time and all of the advertising jazz. Now if I "press any key" then the OS goes back to loading the generic drivers again. Somebody please help me. I was told that my motherboard was bad. Could this be fixed?
Yes same thing happen to me with nf325-a7 motherboard i tried different memory and still get that error !!!!!! after install windows xp ... no doubt it is the motherboard and not the hard driver..!
Posted on Sep 15, 2008
Did you change the boot sequence back to floppy before rebooting to install
Posted on Jun 05, 2008
    Novelist:
    Scholar:
  • 104 Answers
Your motherboard could be the problem! But it could also be your memory, hard drive or the file system that resides on the hard drive! I don't think you would've gotten that far if you were having memory problems, but its still possible, however, we'll focus on it being the hard drive/filesystem! Boot to the XP CD, When your given the option to assign hard drive, select the hard drive you want to install to, and delete all the partitions! Then recreate partition(s)! (When you recreate partitions through XP install the first created is always a primary partition, subsequent partitions will be extended!! That means if a partition is already there a newly created partition will be in an extended partition) Now that the partition is created format it(don't quick format do a full format)! then install! If that ends up with an error or the same problem its probably your hard drive or motherboard!(If you go a spare hard drive you can try that to see if it goes beyond the reboot!!) try this first and see how it works out, get back to me if any questions. regards, babb
Posted on May 08, 2007
How to fix my acer extensa 4630z? Its boot manager is missing or corrupted.
First you need:
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, just restart and try to boot to the Windows XP CD again.
  1. Enter Windows XP Recovery Console. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
When you reach the command line (detailed in Step 6 in the link above), type the following command and then press Enter.
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Apr 01, 2015 | Acer Extensa 4630z
How do I rebuild the MBR?
You will need an XP install CD for this and also set the CD/DVD drive as the first boot device.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
  3. When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
  4. The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
    To the Which Windows installation would you like to log onto question, press 1 and then Enter.
  5. The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis. To the Type the Administrator password request, enter the password and press Enter.
    Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
  6. Type fixmbr and then press Enter.
  7. The fixmbr utility will write a master boot record to the hard drive that you're currently using to boot into Windows XP. This will repair any corruption or damage that the master boot record may have.
  8. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a corrupt master boot record was your only issue, Windows XP should now start normally.
Regards.
Aug 16, 2010 | Microsoft Windows XP Professional SP3 Full...
I need a product key im poor cant afford 1 can anyone help me ? email is dodgy_350z@live.co.uk
If I understand you correctly, you are asking for someone who has REPLACED their Windows XP Home Edition with a newer OS to share their former product key. I recommend you repost your request with these parameters.
Aug 01, 2010 | Microsoft Windows XP Home Edition
Hello, how to install windows xp?
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To install Windows XP, use the following steps.
These steps are similar to other Windows OS installations (Vista, Windows 7).
Below is the detailed procedure of installing Microsoft Windows XP:
  • Before installing Windows XP or any other operating system, you should backup all your data. Data can be backed up on a separate partition, if the hard disk is partitioned or you can back it up on external storage devices like CDs or on a network.
  • Restart the computer and go to the Setup menu by pressing F2 and change the first boot device to CD, press Esc and save settings.
  • Insert the CD labeled Microsoft Windows XP into the computer and restart the computer.
  • When the pc restarts, a message will appear telling you to press any key to boot from CD, press a key immediately the message appears and the setup process will begin.
  • After the files have been loaded, Windows will start and it will give you an option of repairing using Recovery Console by pressing “R” or continue with setup by pressing “ENTER”; press enter to continue with setup.
  • Setup will list all your disk partitions, highlight the partition where you want to install Windows, this is mainly partition “C”, press “D” to delete the partition, then press “L” to confirm.
  • Highlight the partition you deleted, and then press “C” to create a new partition, press “ENTER” to create the partition.
  • Press “ENTER” again to install Windows on the New (Raw) Partition you have created.
  • Format the partition using NTFS file system.
  • After format has completed, Windows will restart and setup will prompt you to boot from CD again. Ignore the message and let setup continue automatically.
  • Follow the next steps which will ask you to setup the system Time and Date, Network and enter a serial key, until setup finishes.
  • After setup has finished, Windows will restart and will welcome you for the first time; Microsoft Windows XP will have successfully been installed on your computer.
Jan 08, 2010 | Computers & Internet
Stop:0x0000007B tried to boot in all modes..we go to blue screen with stop: cannot get a command prompt either
Issue : Blue screen with Error0x0000007B
Solution
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
The above error comes if the boot volume is corrupted and cannot be initiated by Windows XP. or You are installing Windows XP on a mirrored boot partition that was created by Microsoft Windows NT 4.0.
To completely resolve your issue i think you have to reinstall the OS.
Have to format the Hard drive
requirement
the OS - XP Home / Premium Installation CD
Disk formatting is the initial part of the process for preparing a hard disk or other storage medium for its first use. The disk formatting includes setting up an empty file system. A disk formatting may setup multiple file systems by formatting partitions for each file system.
Check this following Video Link
Help you with uninstall and reinstall the XP
Jan 03, 2010 | Dell Microsoft Windows XP Home Edition
My computer was fixed by a person who installed xp pro on it but he didn't have a validation key. Well i found my original install cd with the xp home edition and i want to do a clean install to install...
really simple just turn put the cd in turn off the pc and reboot, your cd drive should pick it up on boot up from there its simply following directions
Jun 24, 2009 | Computers & Internet
Bsod, error code:0x00000024, hdd problem booting xp os
Can you do this
Boot from the Windows XP CD.
Select your OS and enter password (if needed)
When you reach the command prompt type the following and then press Enter:
expand d:\i386\hal.dl_ c:\windows\system32\hal.dll
Using the expand command as shown above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\windows represents the drive and folder that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite the file, press Y.
Apr 24, 2009 | Sony VAIO VGN-T170P/L Notebook
Repair start up failure
Well it depends on how severe is your start up problem, if the OS still loads lets say on Windows XP more or less you just have to repair the boot.ini, if you have your Windows XP CD load it to your computer(make sure that on the BIOS setup the intial boot devce must be your CD ROM) When the initialization finished press R to open the command prompt the type the following;
bootcfg /rebuild
Oct 04, 2008 | Computers & Internet
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
Press R to Enter Recovery Console
Choose the Windows Installation
Enter the Administrator Password
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
  4. The next prompt asks you to Enter Load Identifier:.
  5. The final prompt asks you to Enter OS Load options:.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Biostar NF325-A7 Motherboard Logo
114 people viewed this question
Top Biostar Computers & Internet Experts
Alun Cox
Davit Mamyan
Davit Mamyan
Marvin
Marvin
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
