Adding memory 1 OR 2
I installed a new mermory chip to my eMachineT1840 and was wanting to know if could put 1 in place of the 1 that is in there from the factory also with out loosing anything like my musci and excetera.
  • kefauver7 Jan 05, 2009
    Thank you for being there.I am going to put another chip in where the original one is .
  • 61 Answers
The answer is yes.
If this is the type if memory your talking about: http://en.wikipedia.org/wiki/RAM, then you can remove an old one, and add a new one without losing any computer files or information. (Before you install the new ram, please make sure to shut off your computer!)
I hope that helps, MC.
Posted on Jan 01, 2009
    President:
  • 948 Answers
Adding or removing memory will have no effect on any data stored on your computer's hard drive (where your music is).
My e-machines will not let me upgread my ddr2 1eb memory
That Machine would take DDR2 PC2-5300 upgrade chips. The max that system could take would be two 1GB sticks for a total of 2GB or 2048MB of memory. Memory is fairly easy to damage with static discharge and is also very easy to not put in all the way. When putting it in, unplug the power from the computer, push and hold the power button for 20-30 seconds to help discharge power from the computer, Line up the pins on the memory and push them into place till the little arms at the sides of the slot pop up and click into place. I'd install one chip at a time, powering the machine up after the first chip to make sure it works, then starting over again. The only time I'd install both chips at the same time would be when installing a memory kit (two or more chips in one package), in which case, install both chips before powering it on.
Jan 13, 2013 | E-Machines T5082 PC Desktop
I can't close tower cover
When your computer appears to slow down, one way to help increase its speed is by adding memory. You can easily purchase memory chips from various online sources or if you have a Dell Dimension and want to stick with Dell products, you can purchase additional memory chips from Dell itself. It is not difficult for a non computer person to add memory to a Dell Dimension, although sometimes, it is cheaper to purchase a new computer and then install additional memory.
Shut down your computer, turn the computer off and unplug it. Open your computer case. There will be two thumbscrews on the back of the Dell Dimension computer case that will release the cover. The side of the computer case will then slide backward and lift away from the rest of the box. Locate the slots for RAM. These are short off-white slots that are near the power supply on the motherboard. They will be slightly longer than the RAM you are about to add. There will be at least one RAM chip already in place in one of the slots. Place your new RAM chip into a blank slot gently. It does not matter which slot you use; any will work. When you press the RAM into place, be sure the notch on the chip lines up with the slot. There will be a guide on the slot to ensure that you do not insert the chip backwards. Press down on the RAM chip until it locks into place. There are two guides on the side of the slot that will snap into place on the sides of the chip to ensure the chip does not fall out. It will take a bit of pressure to make the chip snap into place, so press straight down into the motherboard to get the chip in place. Close the computer case, put the thumbscrews back where they belong and start up the computer. Your Dell Dimension will sense the new RAM, which will be available to the operating system when the computer starts up. Hope this helps.
Dec 30, 2012 | Dell Dimension 4600 PC Desktop
Emachines T5082 Adding 512Mb ram. Getting slot 0 installed slot 1 not installed.
Try swapping the memory in the two slots. It sounds like either one of the memory chips is bad or one of the memory slots is bad.
If you find that one of the slots is bad, then you might try just putting a 1GB Chip in the slot that works.
Apr 24, 2012 | E-Machines eMachines Desktop PC
Dell inspiron 1501 will not start up after adding memory
If it worked prior to adding the new memory check the following. 1. how much memory does the laptop support and how much have you put in. 2. what is the speed of the memory you purchased vs. the spec for the laptop. 3. Is the memory properly seated. 4. If there are 2 chips make certain they are compatible. 5. try one chip at a time to see if one is bad (you could have gotten a bad piece of memory!) 6. Put your original memory back in and go here http://www.crucial.com/?gclid=CIfh7uHHm6ECFRRM5QodeGQlzw&cpe=pd_google_us&ef_id=1705:3:s_09358bad9ffd2090a57cd12ae34889fd_482416823:S9DpU9BbrmIAAFWPDosAAAFA:20100423002659
This is three steps to get the proper memory modules. Works 100% of the time! Good luck Let me know how you make out Phil
Apr 23, 2010 | Dell Inspiron 1501 Notebook
I want to install a memory upgrade how do I do it?
Desktops have 2 to 4 memory slots. If you have spares, you can do one of 2 things, remove a memory card and take it in for a match (2 more 1 gig chips is killer). If you only have 2 slots, take a chip in and ask for 2 more chips - that total the increased size that you desire.
Thanks to Microsoft's fat windows design, you will need a minimum of 2 gig to run vista and 1 gig to run XT. BTW, the term "fat" was not intended to be a compliment.
Once the new chips are installed, just turn the machine on and it will recognize the new memory and adjust accordingly.
Oct 14, 2009 | Computers & Internet
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Adding memory to hp dv5000
On HP laptops the memory chips are usually stacked, sitting almost on top of each other...if the memory chip that's in there now is sitting in the first slot you may not be able to see the second slot below it. If that is the case, remove the chip that's in there now and install your two new ones.
Jan 19, 2009 | HP Pavilion dv5020us Notebook
PC want start after replacing memory card
Hello
1. Make sure that your computer supports 1Gb on 1 slot.
2. If you touched the chips with your hand you might have BURNED the chips with static electricity from your hands.
3. But before you start panicking check if you have moved the video card, if you did the PC won't show up anything and will halt at start up.
3. One last thing you might do to get the computer booting up again is to remove the CMOS battery for say 1 minute and then put it back in place to reset CMOS just in case. Then plug in your old memory in place turn off replace and try the new one. turn off try install both (never touching the chips on the RAM) and turn on again.
Hope that this helps :)
Jan 07, 2009 | MSI K8MM-V Motherboard
Installing Memory
put the new ram in slots 2 and 4.
Slots 1 & 2 are channel 1 slots 3 & 4 are channel 2, you need matching sets in each channel to run dual channel mode.
Jun 09, 2008 | Gateway 507GR PC Desktop
Mermory card for samsung moblie phone
the card actually inserts looking as though you are placing it in the mobile upside down. It will locate and lock into place. To remove after wards simply press in and it will jump out.
Easiest way to put music on it as mp3s is to copy them from a pc and then put the card into the mobile afterwards
Dec 27, 2007 | Samsung SGH-D600 Cellular Phone
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
