Question about Panasonic SC-PT960 Theater System with Wireless Speakers
Disc wont eject
When i click the "open/close" it says:"Locked... w1"
and i dont know how to unlock it !
for the panasonic sc-pt760
  • Panasonic Master
  • 19,396 Answers
Try first unplugging unit from main, and holding the cancel button.
If that does not work try the following:
Hold at the same time the stop button on the main unit and key >10 on the remote control at the same time for about 5 seconds, until you get the word "initialised" on display. This will reset the unit to factory settings.
Posted on Aug 25, 2009
FYI, I tried Ginko's suggestions and could not get it to work. The nearest authorized service center says the part will be about $100 plus about $65 for labor = 185 inc tax (exactly half the price I paid for the unit 1 yr and 3 months ago). Decision decisions...
Posted on Mar 17, 2010
I had to replug things in for my dish and unit sat sidewards to get to plugs. It now says locked and can eject disc, select source. Help
Try this:
Press and hold [?] (Stop) on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again.
All settings should return to the default values.
Not saying it will work though!
Not
Dec 31, 2015 | Panasonic...
Panasonic Home T, sa-pt760, message LOCKED
While the unit is on, press and hold the play button and the power button, display should say unlocked. If this doesn't work, try it using the stop button and power button.
Apr 03, 2013 | Panasonic Audio Players & Recorders
How do you unlock the tray for the panasonic sc-bt200 .when i press the button to insert a disc it says the word lock and it won"t open
Cannot eject disc. ≥The unit may have a problem. While the unit is off, press and hold (>> / >>I) and (< OPEN/CLOSE) on the main unit at the same time for about 5 seconds. Remove the disc . After disc removal or if this does not work you may need to reset to factory defaults. for the player alone.
To return all settings other than some settings to the factory preset.
≥Select “Yes” in “Restore Default Settings” in the Setup menu.
This returns all values in the Setup menu and the on-screen menu, except for “Remote Control Code”, “On-screen Language”, “IP Address/DNS Settings”, “Proxy Server Settings”, “Network Service”, “DVD-Video Ratings” and
“BD-Video Ratings” to the default settings.
If this does not work then you may need to reset everything to the factory settings.
To return to the factory preset. Everything Reset.
(No setting)
≥Reset the unit as follows:
1 Press [POWER] on the unit to turn off the unit.
2 Press and hold (>> / >>I) and press [POWER] and [< OPEN/CLOSE] on the unit at the same time for more than 5 seconds until “PLEASE WAIT” is displayed on the unit.
3 The power is turned on and then turned off automatically.
Cheers!
Feb 15, 2010 | Panasonic SC-BT200 Home Theater Systems....
Chgr error on my panasonic pt760 discs will not eject
Lock123 already solved my problem great service no wait time your site is the best one out
Jan 24, 2010 | Panasonic SC-PT960 Theater System with...
Panasonic sc-pt1050 just displays close. Ive tried unplugging it and leaving off for a while, but that didnt work. The disc tray is closed and when it turns on it dosent even try to read the disc nor can...
I have the same exact problem. Turns out my toddler has stuck a piece of paper in the tray, so the tray was just stuck. I just undo the four screws on the side and 3 in the back, lifted up the top cover, remove the paper causing the jam, put everything back together. Problem solved. Saved $140 from having to sent it to Panasonic
Jan 18, 2010 | Panasonic SC-PT1050 System
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
I just bought a dvd home theater system sc-pt760 and i have a 42 inch LG flat screen and the sound wount work on AUX for the TV
Are you using the HDMI connection on both units, the SC-PT760 does have a HDMI input Yes/NO ? If not then it has HDMI output to the LG for HD Picture. What I would do if no HDMI INPUT to the SC-PT760 is available, run out of the TV with the Digital connection into the SC-PT760 Digital Audio in, assign the input as tv and you shoild get TV audio out of your home theatre, you could also use the analog connection audio out of the tv to the home theatre but this would not yield a dolby digital sound.
Feb 02, 2009 | Panasonic Home Theater System System
Panasonic sc-pt760
LOL if you just paid good honest hard earned cash for it i would certainly take it back. You might get a few freebies in the process. If you never broke it, Dont try and fix it because you will be held responsible for any damage they deem fit to blame you for.
Oct 17, 2008 | Panasonic Home Theater System System
Unlock panasonic sc-rt 50 home theater
theater sound system sa ht540 region hack
Mar 18, 2008 | Audio Players & Recorders
Panasonic home theater
take it apart via the screws on the side and back and then there is a white lever you can pull to unlock it. make sure you are wearing shoes because you dont wanna short the system
Sep 09, 2007 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SC-PT960 Theater System with Wireless Speakers Logo
1,534 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
