Question about Palm Z22 Handheld
Palm Pilot: Connection for Hot Sync
This is a Palm Pilot problemTrouble with hot sync:On tapping Hot Sync, I get the message "connecting with the desktop using cradle/cable." This then becomes "connection between the device and desktop could not be established. Please check your setup and try again."I've checked dozens of times. 2 different cables. 3 different USB ports.I am running a Mac iBook G4 on system 10.5.
  • jclick81 Feb 02, 2009
    The sync does not get completed and it was working fine every other time. I have tried different cables and different USB ports.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Has synch worked before on this set up?
Posted on Jan 01, 2009
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
When I try to hotsync I get a message telling me that connection could not be established. usb ports are ok. cable works. idid a soft reset. ray
It sounds like you have the settings wrong in the software on your desktop. If you are trying to hot sync it and your desktop software is set to sync it a different way other then by USB cable you will get that error message. Here is a link to a step by step guide of problems and solutions. Hope it helps.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/solutions/article/2630_en.html
Aug 15, 2009 | Palm Z22 Handheld
Need Hot Sync module on backup PC
Plug your E2 into your pc and when it says new hardware found, install the cd. Do not continue till you have verified sync connection between pc and pda
Dec 11, 2008 | Palm Tungsten E2 Handheld
Cable hot sync is always not going through
I had the same problem on the connection and it turned out just to be so simple as some dust/dirt in the connection surface for the sync cable. I fixed it by cleaning the connection surface with isopropanol. That helped.
Nov 11, 2008 | Palm Treo 650 Handheld
Data hot sync
I am soo sorry Randy i accidentally ended your chat!! My internet connection went down!!
To contiue helping you, once the software is reinstalled, please try to sync again.
Oct 15, 2008 | Palm TX Handheld
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Hot sync
Try reseting the palm.
Jan 02, 2008 | Palm Treo 680 Smartphone
Palm M515 hot sync problem
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Hot sync does not complete!
Something similar happened to me due to incorrect periodic entries in the Datebook, try disabling all elements in the Hot Sync, try it, and if it works, then add them one by one until you find the offending one, then focus on clearing that DB.
(Actually i simply stopped synching Datebook since i didn't wanted to loose all the history of appointments i have).
Nov 04, 2007 | Palm TX Handheld
Manual Hot Sync
If u need to make connectivity between computer and Palm mobie then u need to install hot sync software on ur Pc and activate hotsync option from ur mobile then with cable u can transfer the data . if u  not have proper software of hotsync then download it from palm Site.
Gizmo1
Oct 22, 2007 | Palm LifeDrive Handheld
Palm Z22 Handheld Logo
213 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
