Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Lamp light flashing tv wont come on
We just changed our lamp and now the red lamp light is flashing. The tv wont come on. Is there some kind of reset button? We put the old one back in to see if it did the same and it did. (The old one worked it just was old)
  • 1 more comment
  • babzeebab Jan 03, 2009
    there was a switch (blue) on the back of the tv where the lamp plugged in that wasn't being set so my husband wedge a piece of metal in there to flip it and the problem was solved.
  • b_h396 Feb 06, 2009
    changed the lamp light it is still flashing and power won't stay on it is hitachi 50V500A 50in. LCD
  • johnkrol Feb 27, 2009
    I'm having the same problem !!!! You suggested check that lamp cover?
    What lamp cover.
  • 10,594 Answers
No reset of lamp hour is required. If lamp is original form Hitachi then check Lamp Cover, it might not put back or not seated well.
Posted on Jan 01, 2009
  • Shahid Electronics
    Shahid Electronics Jan 03, 2009
    Thats great. proble resolved.
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have a 65737 Model Mitsubishi DLP TV. I changed out the DMD formatter Board and DLP Chip Yesterday and now the Lamp will not come on. It worked fine until I changed the Board because it had Vertic
Hello, make sure all the covers are on correctly, then recheck all the wiring connections, unplug each one and inspect them for a bent pin. Let me know....tks
Jan 03, 2015 | Mitsubishi WD65737 65" DLP TV
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Tv wont turn on, when i press power on the remote, the red power light flashes for a second but nothing happens, is there a reset button?
reset button is usually under setup>picture>other. however your problem may be because of the lamp. If your TV is 4-5 years old you may need to change your lamp.
May 10, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
LAMP LIGHT ON AND TEMP LIGHT, TELE WILL NOT COMME BACK ON
Look in the owner's manual. These lights indicate the current condition. Usually the lamp light will go on if the lamp has failed and similarly the temp light if the fan has failed. With both, there may be a different problem. If you can confirm your model number, I can look up the problem indication as well.
Thanks,
Dan
Aug 25, 2009 | Hitachi P50S602 50 in. Plasma TV
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
176 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
