Trouble connecting Peavey (PV14) mixer to pc.
I have the peavey pv14 (no usb port) mixer, I need to connect the mixer to my pc for my home recording studio. How would I connect mixer to be recorded using cakewalk software.
  • xodus Jan 02, 2009
    How would I connect to to the pc usb. How I'm I to connect fm the mixer?
  • 163 Answers
first add a new USB ports using onboard usb hub.
Posted on Jan 01, 2009
The voltage out from supply just jumping all time from about 38,1V constantly to 46,4V - WHY??? How many VOLTS should be????
1- Are you measuring with the mixer connected ? The supply needs a load to work right.
2- If so, you have a blown regulator inside the supply, or maybe a bad solder somewhere on the board, probably a condenser...
Feb 16, 2015 | Peavey PV10 USB Mixer
PV14 volume output shuts off and sometimes has intermitent static when adjusting slides
The slide-type volume controls are defective and will have to be replaced.
Jan 08, 2018 | Peavey Electronics Peavey PV14 Mixer
Slide pots for PV14 mixer
The pot needs to be cleaned. Get a spraty can of DeOxit 5. Spray it into the track and move the slider up and down a number of times. If that doesn't fix it, replace the slide pot.
Jul 30, 2012 | Peavey Electronics Peavey 00512140 PV 14...
Peavey pv14 right side stop working all of a sudden how do i fix it?
you could have blown the output on that side,, here are some other things you may need to know about that mixer I have seen the manual for this unit in the past and it really doesn't give many details of what all can be used for this mixer,, However that seems to be par for most unpowered mixers, I do know that if your using a mic with it,, its very choosy on which ones work , and those that have issues
Sep 11, 2011 | Peavey Electronics Peavey PV14 Mixer
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
How do you hook up a peavey pv14 usb mixer to non-powered speakers?
You'll need to provide an amplifier if there isn't one built into the speakers. All the mixer does is combine audio sources and provide a line-level output. A separate amplifier is needed to boost that to speaker level. If you're just using the mixer in a home setting and you have a stereo receiver or home theater system, you can feed the mixer's output to an auxiliary input on the receiver and use the speakers you have connected to that.
Feb 25, 2011 | Audio Players & Recorders
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
