Question about Epson Stylus C44UX InkJet Printer
I've got an epson stylus c44ux printer. It recently had a paper jam and now the red light is on constantly. There seems to be no way to reset it. I've replaced both ink cartridges, cleared all paper from inside the printer (there's definitely nothing left) and generally driven myself mad trying to fix it. Having looked on the web, it seems that other people have had an identical post-jam problem and found no solutions. Any help greatly apprecieted.
    Problem Solver:
  • 10 Answers
You may try to do the following:
1. Turn the printer off and unplug it from the power source.
2. Remove any obstruction or any foreign material inside.
3. Check if the inks are clicked into place on their correct slot and and cartridge cover is closed properly.
4. Turn the printer on.
If same issue persists, it might be a hardware failure. Or you might want to contact Epson for further assistance and/or troubleshooting for that matter.
Posted on Jan 03, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My printer had a major paper jam and now the red
please use this URL http://files.support.epson.com/pdf/sc40ux/sc40uxpg.pdf to resolve this issue, and please revert either solve or not, Regards
Mar 16, 2010 | Epson Stylus C40UX InkJet Printer
Red light constantly on
First, disconnect your printer from the power supply socket(not your pc) then after a few minutes, reconnect and see if the printer has reset and back to normal.
Should this fail, uninstall and then reinstall your printer.
Please send feedback if this works thank you.
Feb 24, 2009 | Epson Stylus C44UX InkJet Printer
Epson c44
If the green light and the red light is on (neither of them blinking), this means either you have an empty or faulty ink cartridge, or you have a paper jam. Replace both cartridges; is the problem solved? If not, make sure there are no shreds of paper jammed in the paper feed path anywhere. No? Then you need to get a technician to look at it. However, if you want to try dismantling the printer yourself to see if you can find the reason for the jam, report back and I can provide further information.
Nov 09, 2008 | Epson Stylus C44UX InkJet Printer
Flashing Green and Red lights
i querried from epson site it says the ink is low, repalce cartridge
Step 1 WHICH MODEL ARE YOU USING? Stylus C44UX Step 2 What were you doing when the problem occurred? Turning on the printer Step 3 What happened when you were turning on your printer? An error appeared on its control panel Step 4 What is the power light's current state? Flashing Step 5 What is the error light's current state? Flashing Step 6 WHAT IS THE PRINTER'S STATUS? Ink low
Oct 28, 2008 | Epson Stylus C44UX InkJet Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus c44 printer
try to download (ssc sevice utility) this sorftware enables you to reset the life of a lot of epson printer's consumable parts, like for example is the cleaning section, if this part reaches its life limit, your printer will stop operating.
Sep 26, 2007 | Epson Stylus C44UX InkJet Printer
Epson Stylus C44UX InkJet Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
