You will need to contact the manufacturer for replacement burner nozzles. As Propane is at a higher pressure, the nozzles need to be smaller in diameter.
You will also need a tank fitting for Propane with a regulator attatched - and a large spanner to attatch it.
Make sure any pipe connector to this is fitted with an approved hose crimp, as "jubilee" type clamps are not recommended.
If you just fit the regulator, the burners can flare dangerously on the high settings - unless it has been designed to be dual fuel originally, and have replacement nozzles.
Was this helpful?
Yes
No
Popular Solutions for Barbeques Galore Turbo Elite
The flame isn't getting high; oil not heating. Checked the tanks, they are full.Regulator valve...
(More)
The flame isn't getting high; oil not heating. Checked the tanks, they are full.Regulator valve doesn't seem to work properly
we just purchased a bradley digital smoker and when we turn it on it just beeps and gives a e1...
(More)
WE JUST PURCHASED A BRADLEY DIGITAL SMOKER AND WHEN WE TURN IT ON IT JUST BEEPS AND GIVES A E1 MESSAGE WHAT IS WRONG WE CANNOT ADJUST THE SETTINGS
