Question about Symphonic SC319C 19 in. TV/VCR Combo
VCR keeps trying to eject a tape...even when there is no tape inside the VCR.
I currently have a Symphonic TV/VCR combo. I've had it for a few years and love it. However, ever since i've moved it constantly attempts to eject or rewind or play a VCR tape, when there is no tape in the player. I've looked inside and notice that there is nothing inside (like a sticker off a tape) that should not be there. I was wondering if there was a way of simply turning off the VCR aspect of the set and keeping the TV working just as it is (without the VCR and without the constant attempts at ejecting). Any help would be greatly appreciated. Thank you
2 Suggested Answers
SOURCE:
Danmart
  • 291 Answers
SOURCE: tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
Posted on Aug 04, 2008
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Tv cuts off
being it was older and a left over gift....we trashed it and saved my husband's blood pressure.
Aug 06, 2008 | Symphonic Televison & Video
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
MAGNAVOX TV /DVD,VCR CUTS OFF
is the VCR trying to eject a tape even if there is no tape in machine. then shutting down ? if so the vcr sensors need to
be replaced
sensors avalible from funai
Jan 03, 2008 | GE 13TVR72 13 in. Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Tv vcr combo
Nov 16, 2007 | Symphonic SC319C 19 in. TV/VCR Combo
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Symphonic SC319C 19 in. TV/VCR Combo Logo
82 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
