Question about Garmin nuvi 200W GPS Receiver
NEW GARMIN MISSING SOTWARE MODEL NUV1 200W
  • 4 Answers
I did exactly the same thing!. This is how I fixed it.
Use Updater.exe NOT WebUpdate. Download the latest firmware for your unit (the rgn file), then connect your nuvi via usb. Turn it on and hold the power button left, at the same time drag and drop the rgn file onto the Updater,exe. It will start automatically and reload the firmware over the corrupt one.
Here are the files:-
http://e-trex.info/fw/nuvi/2x5w/fw_nuvi2x5W_ID0827_en_v460.rar
Enjoy
Posted on Jan 03, 2009
Update file on garmin corrupted
Same happened to my Garmin Nuvi 760, power failed during upload. Files corrupted. Garmin could not locate it with Sat. Told me to trash it and they would give me $70 towards purchase of a new one, which would not fit in my cars receiver. My solution was to purchase a used one that had a good Garmin File folder. I copied the folder to my pc. It was important to remove the device file from the copied folder. I then formatted my corrupted 760. Then copied the folder from my pc into the formatted 760. Next step was to use Garmin Express to replace the missing device file, do the updates, and reinstall the maps. Product code to unlock maps was inside the rear plastic housing to unlock the maps. Whole process took about 4 hours and it works like new now.
May 02, 2012 | Garmin nuvi 255W GPS Receiver
My gps (Garmin 255) is not recognized by my computer. There is no system sotware. I tried the webupdater of Garmin but it doesn't work. Thanks
Try using a different USB port it may not be getting enough power to the unit, also make sure that the unit is fully charged.
Hope this helps!
Dec 09, 2010 | GPS
Goes to pc mode when plug into car
This is caused by wear on the mini usb socket at the back of the satnav. The plug is not pushed in fully though it appears to be. Push it in further and it will be ok
Sep 04, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin 276c indicates "Battery Missing" even with a new Batt.
Check the battery contact points inside the unit. There may be a thin film of crud (oxidation) that prevents contact, especially if the previous battery had any signs of corrosion.
Jul 02, 2009 | Garmin StreetPilot c550 GPS Receiver
System software missing garmin 250w
If the unit indicates "software/firmware missing", then you can only try to re-install firmware by running WebUpdater again. If it doesn't work, then the unit has to be sent to service to have it re-flashed.
Jun 03, 2009 | Garmin nuvi 250W GPS Receiver
Solutionhttp://www.gpsgarmingps.com/Copias/SoftwareMissingIng.htm
May 09, 2009 | Garmin nuvi 250W GPS Receiver
Garmin nuvi system software missing 265W i try to update my garmin nuvi 260. I see on the screen: sytem software missing. I cannot do anything else. Please, help!
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Feb 22, 2009 | Garmin nuvi 260W GPS Receiver
SISTEM SOFTWARE MISSING on my Garmin NUVI200 GPS
All Garmin users,
There is no easy solution for this except to return your unit to the nearest Garmin outlet. You need to have very special equipment called an E-Prom burner or writer which only Garmin have. With this equipment they re-programmed (restore) the operating system back on your specific Garmin unit and model.
The problem why anybody can't do it is because there is no way you can access your Garmin unit from a pc or mac if the operating system is lost or damage on your Garmin, for the simple reason your pc or mac can't reconize the device that is pluged in, because there are no communication platform between the two devices.
As simple as that, life with it or send your Garmin gps to an autherized professional Garmin dealer.
Marius Oosthuizen
Garmin dealer
South Africa
Jan 19, 2009 | Garmin nuvi 260W GPS Receiver
BEFORE you connect the Garmin to your computer you must download the free Garmin program on your computer called UPDATER. Did you do that?
If not:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater AFTER installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin Nuvi 200w shows system software missing.
I had the same thing happen. I called customer service
(1-800-800-1020). They linked to my computer (nuvi was pluged into it)
and fixed everything!
Dec 24, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
366 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
