Hi Vicki,
1. The yellow arm sticking up that has two notches in it is supposed to have a spring attached to it. That is what causes the tension. It doesn't look like a spring is attached in the video.
try this link-it will take you to the owners manual and a picture of the belt routing. copy and paste the link into your browser
https://groundscare.custhelp.com/ci/fattach/get/51655/0/session/L2F2LzEvdGltZS8xMzUwNjkwNjczL3NpZC9jbm10RTg5bA==/filename/275+-+LX266+LX277+LX277AWS+LX279+LX288.pdf
SOURCE: i need a diagram to install a deck drive belt on a
Need to know what series it is 120 240 and so on you can go to this web site and select the mower thats yours. once on this site choose your mower and you can get belt diagram there. there is also a Phone number if you can't find your mower. Thanks for using Fix-ya And rate this answer if it was helpful.
avid101
http://www.deere.com/en_US/ProductCatalog/HO/servlet/com.deere.u90785.cce.productcatalog.view.servlets.ProdCatProduct?pNbr=SKU21309&tM=HO&link=enav
SOURCE: i need a deck belt diagram for a John Deere 170
I recommend that you go to any john deere dealer and get a john deere replacement belt. What you will find if you go with a generic is that it will not be quite as good, and will not last.
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
