Question about Apple iBook G4 Mac Notebook
IBook G4 Fan keeps running
When I insert a DVD, the fan keeps running an the computer heats up -- only way to shut down is to remove the battery.
  • JDTec
    JDTec May 11, 2010
    The fan keeps running because it is trying to cool the processor or the memory. You have to get it checked out befroe it causes more damage.
  • 160 Answers
Next time you experience this, go to utilities.activity monitor..it will show you what program ir running the "hottest:, and the graph will display what is currently going on. you may have something running your not even aware of...
Posted on Feb 18, 2009
Stuck dvd
Where your cd drive is there is a small hole which you can insert a straightened paper clip into and this should eject the dvd. Hope this helps.
Nov 22, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
My ibook G4 has stopped reading my external dvd drive.
If you external DVD drive connects via USB, try rebooting your iBook. (Sometimes a static shock will shut down your USB channel, and only a reboot will reset it.)
If this doesn't work, choose "About This Mac" under the Apple menu, then click on "More Info." Under Hardware, click on USB. See if the drive shows up as one of the attached USB devices. If it does not, the drive or cable may be bad.
If you have another computer available, connect your DVD drive to it. This will tell you whether the drive has failed.
Nov 14, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
Laptop runs for 20 minutes and starts to fail. If
It is heat related. This is computer trying to make sure that no damage is done to it. Take it to a mac repair centre to get it checked out
Oct 27, 2009 | Apple iBook G4 Mac Notebook
Blank, doesn't boot, and seems to shut down in under 15 minutes.
My nephew's W350A had the same issue last year. It turned out that the CPU was loose in its socket and not allowing the POST cycle to run. You will need to remove the back cover and the bracket that goes across the CPU. Remove the CPU and clean the pins with a little rubbing alcohol, re-install and you should be fine. Remember to aply a little more heat-sink grease across the top of the cpu before putting the bracket back on. This will help keep it running cooler.
Apr 18, 2009 | Computers & Internet
Apple ibook crashed when on MS Word. Black screen fan running???
Sounds like you have a problem with the logic board. This appears to be a common problem with iBook G4 related to the fit of the logic board (ie motherboard) within the case.If you were to take it to apple store the likely fix would be to replace the entire logic board which is very expensive and probably not fiscally sound on a 5 year old machine. Another option would be to try to fix it yourself. If you are feeling brave you can dissemble the laptop and attempt to shimmy the logic board back into position.
Here's a link that detail the approach. http://www.coreyarnold.org/ibook/. This guy had success on two ibooks that had the same problem and they have been working for 2 years since he did his repair
Also, here is a link to a forum that may offer you a few more approaches to solving your problem. iBook G4 won't boot up - fan running & black screen - AppleNova Forums
Hope this helps, good luck!
Mar 30, 2009 | Apple iBook G4 14-INCH Series M7701LL/A...
Dvd will not eject from my iBook G4
Hold down the Apple and the E when you restart your computer.
Mar 13, 2009 | Apple iBook G4 Mac Notebook
How to replace clock battery of ibook G4 laptop
Replace the on board capacitor with a Panasonic Capacitor 5.5V 0.22F Model number:EECS0HD224H cost about $3 . You will need to desoldier and soldier the new one on, it's easy even for a novice.
It is a kind of on board battery contrary to what most idiot mac users say as a battery IS a form of Capacitor.
Feb 12, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Ibook G 4/12.1/1.33/5aptx.....will not start
Some computer react this way when the logic board goes bad or have a defect in it.
First, Try this:
Remove the battery.  Plug back in the power cord, then press and hold down the power button til you hear a loud beep sound. then release it.  If the computer starts back up... Then you should be okay.
If not, it may has something to do with the logic board.
Let me know if the above works... We may can try some other things if not.
~ enov8
Jan 07, 2009 | Apple iBook G4 Mac Notebook
No luck
Probably the dvd drive is damaged (boot the computer with a bootable cd and see if it works, if not, change the drive), or it might have weak connection in it's slot, remove it and reinsert it in the laptop, see if it works.
Jan 16, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple iBook G4 Mac Notebook Logo
207 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
