Question about InFocus (HW-HTSCREEN76) 76" 16:9 Projector Screen
Projector emitting sparks
My 6 month old refurbrished Infocus 76 projector was working fine when all of a sudden the bulb quit, smoke and light started flashing from within the unit and then some sparks making loud arcing sounds. The violence quit, the power light on the projector was blinking red with a high pitch whining type sound until I pulled the plug. I did pull it as quickly as I could, took time to get to the unit from where I was sitting.
I removed the bulb thinking this may be the problem, but the blub looks great and no burn marks in that area of the housing. I did not open the case any further.
The projector is being used for home/indoors.
  • 2,237 Answers
The ballast blew and needs replacing. if it was the power supply, the led wouldn't be on.
Posted on Aug 03, 2009
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
Projector attempts to light the lamp, but to no avail
the ballast is gone and needs replacing. unfortunately, infocus has no parts for that model.
Oct 30, 2009 | InFocus Office Equipment & Supplies
InFocus LP650 will not come on
First try a firmware upgrade. If that doesn't help, it seems it might be a power supply issue since you said the led comes on very light. I repair these power supplies. My ebay id is gtitubro
May 29, 2009 | InFocus LP650 Projector Lamp
Infocus 4805 Lamp will not ignite after new bulb and reset.
it there is no high-pitched squeal when it starts up, the colorwheel needs replacing. the lamp won't light without it. the part is under $50, but installation is quite involved.
Apr 16, 2009 | InFocus ScreenPlay 4805 Multimedia...
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
InFocus IN74 Projector Fault
Hi there.
How many hours had it done? The bulb may have expired and as a safety precaution the projector will not switch on, otherwise the bulb will explode causeing further damage.
Cheers
Feb 23, 2008 | InFocus X1 Multimedia Projector
That color is not listed because it is either Green or Red. There is no Blue, if you are getting Blue, you have something that is extremely unusual.
Feb 16, 2008 | InFocus LP650 Projector Lamp
Infocus IN26 Projector
Yes the problem is due to over heating.It would be perfectly acceptable to have inlet air to the projector that ranges between 70 ? 76 Farenheit. Most projectors are designed to operate with inlet temperatures well above this value, usually up to about 90F.Set your air-conditioner to the value specified and it should work fine..
Oct 09, 2007 | InFocus IN26 Multimedia Projector
InFocus (HW-HTSCREEN76) 76" 16:9 Projector Screen Logo
259 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
