Question about LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
How can i get my cd rom cable
My cd rom cable is broken my cd rom is not reading where can i get one
    Scholar:
  • 157 Answers
You can get in some computer shops and tell you need IDE cable for cd rom.
Posted on Jan 03, 2009
When i put a cd, the drive doesn't read the cd it doesn't start to work.
Check all of the cables connecting the CD ROM (To be more specific, check your ATA/SATA cable)
Dec 27, 2010 | Toshiba (XM5302B) Internal 4x CD-ROM Drive
I cannot hear sound system play cds and videos
Every CD/DVD-ROM drive has an audio port opened. An audio cable connects to the back side of the CD/DVD-ROM and connects to the motherboard. Most MB's have two four pin audio ports, one slot white in color and a second black in color. As far as the CD/DVD-ROM not reading the disk. Make sure the disk is free from scratches; oils from you're fingers or just plain dust. Open the drawl and blow out the CD-ROM drive or buy a CD cleaner which will clean the internal laser. These days it’s hard to find a CD/DVD ROM drive with a warranty longer than 1 year. Most ppl buy a new one when it fails to read CD's.
Cheers'
Mike
Jun 19, 2010 | Intel Motherboard
How can i burn aduio or mp3 disk on the DVD-Rom because my CD-R drive is broken.
Sorry but a DVD ROM or CD ROM can't burn thus called ROM (Read Only Memory) Must be a DVD/RW or CD/RW (Re Writable)
Oct 10, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
The cd-rom drive in my computer has stopped working all of a sudden. The cables inside the tower are all connected however it does not recognize a disc being in the cd-rom drive! I also get a warning that...
Replace the Cd-rom drive, sounds like you may have a bad spindle motor and or Laser assembly. Cd-roms are very cheap these days, and you might consider replacing it with a DVD drive instead, which is downward compatiable.
Sep 28, 2009 | Gateway GM5084 PC Desktop
Hi i was installing a game from Cd suddenly there was a noise and cd has broken don't how exactly it happened, then inserted good cd into it but still DVD RW rom is not recognising it in sense not reading...
it really a strange that cd was broken by your DVD rom...... well tell me otherone cd is properly working in your dvdrom.... if yes then may be cd is not read by your drive but if no then sured your cd drive is corrupt...just change it
Mar 31, 2009 | Computers & Internet
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
CD ROm not working, not reading discs
Try to clean the lenses using a soft cloth.
Also check the connections of the CD Drive.
Also check in contro panel>device manager wether you have a CD Rom drive over there or not. (Mostly if its not there then connections are loose)
In most of the cases connections are loose. And even after that cleaning the lenses if the CD Rom dosent read then may be there is some problem inside the CD Rom assembly or its broken. You will have to get it repaired.
Jul 18, 2008 | Computers & Internet
My cd-rom has trouble reading disks
1.some times this happened the loose connection of the IDE cable,and power cable.
2.so disconnect the IDE and power cables and then connect again.
if not fix
3. exchange the IDE cable of hard disc.
4.if no result,the lens of CD Rom has damaged, you will be have to buy a new CD rom....
thanks!
Mar 02, 2008 | Computers & Internet
Cd-rom drive
try to separate the ide cable. /
Feb 08, 2008 | Computers & Internet
Cd rom reading not accurate
dear teraz, first check the drivers of your cd rom are properly installed, if no install it again , and if yes check the cables of the cd rom of which is connected to the motherboard or change the cable. insha allah your problem will we solved
Sep 04, 2007 | Computers & Internet
LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
108 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
