Question about SPL Dynamics Z2X-820 Car Audio Amplifier
INPUT CAME LOOSE
My input came loose and i need to get inside of the amp to salter it! how can i do this
I just want new batteries for salter scales 9141 wh3r
Fixya does not sell replacement batteries for Salter scales.
Feb 25, 2018 | Salter Health & Beauty
How do i get battery compartment open on Salter kitchen scale model 2006
I went to the Salter website and I could not find that model number.
Salter Disc Electronic Digital Kitchen Scales White
However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
Nov 22, 2017 | Salter Health & Beauty
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
Okay i need to know how to get inside my amp to tighten up my input jack cause i cant play at all on my amp cause i cant get inside it i took off all the screws in the back and trying to get it off is a...
One can overtighten the input jack and "un-rivet" the jack. They are not made very well !!! OFTEN when they appear loose, they HAVE un-riveted the threaded sleeve from the metal inside the jack... that USUALLY requires REPLACEMENT of the jack itself.
The cabinet backs on a lot of these have to be PRIED out as the Tolex covering often makes them tight.
The amp portion is often retained by screws from the top and or sides AND even the two holding the handle on... there are many different configurations. Sometimes the amp comes out the front, sometimes the back. It is easy to shear off the speaker wires when removing some of them.
Dec 18, 2010 | Marshall 15 Watt Guitar Amp
Peavey pv-8.5c input problem.. only one input works
HI...
I work on peaveys quite a bit. That one will need service
A guitar amp / stereo tech would do
Check the web near you for someone
rate my help if this helps
Thanks
Apr 22, 2010 | Peavey PVĀ® 2600 2-Channel Amplifier
I have a Salter 307 kitchen scale. Are there any instructions for disassembling this unit? Removed 6 + 1 screws and I still cannot open the unit. Please help!!
How to open up the Salter 3007 Aquatronic Digital Scale:
1. Look for a hole (covered by a label) on the bottom of the device, not far from the L-R centre line, and about 1-3/4" from the front. Peel back the label and use a small cross-head screwdriver to loosen the screw that can be seen though the hole (needs about one turn, no need to remove it). Place the scale upright, and rotate the weighing pad slightly in a clockwise direction. This will disengage the tabs on the plastic pad which hold it to a metal base, so that it can be lifted off. 2. Remove the six screws recessed around the bottom of the scale. 3. Place the scale upright and gently "snap" apart the top and bottom shells (catches molded into the left and right ends). Be *** VERY CAREFUL *** when doing this as the display is held in place on a plastic bridge by the upper shell. When this is removed the display is loose except for a flexible plastic printed connector strip (which links it to the circuit board). It is *** all too easy for this strip to break away at one end or the other ***.
Apr 01, 2010 | Salter 3007 Aquatronic Digital Scale
How do i contact salter scale customer service i have a waranty issue with a scale
you can contact our customer service by this email address
sales@accurate-scales.com
Aug 04, 2009 | Salter Stainless Steel Electronic Bathroom...
SPL Dynamics Z2X-820 Car Audio Amplifier Logo
Top SPL Dynamics Car Audio & Video Experts
xxxxxx xxx
Are you a SPL Dynamics Car Audio and Video Expert? Answer questions, earn points and help others
