Question about Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95
Sony KF-50WE610 We moved tv a couple of weeks ago across the room and now yesterday we have blue spot on screen and tv seems to be a little dusty inside also when you tap the top of the tv or stomp the floor screen flickers any help is appreciated, thanks Rick
  • Laurie0288 Apr 09, 2008
    we also have a couple of blue blobs as you call them, but on top of that problem we have gone through 4 bulbs since 2005. The last one was replaced 5-7-2007 and a week after the TV started shutting off.(LED would blink 6 times),so we would unplug the unit and reset it. I invested in a tower fan to circulate more air that seemed to work for a while, then we had to turn the fan on medium then high and now the TV is shutting off again. We can only watch it for 30-to 40 min. at a time.Could I hav gotton a bad bulb? I should mention when we replaced the bulb last time we also had the fan checked and cleaned and a new thermal kit put in.
circuitcity
  • 137 Answers
SOURCE: Green spot on picture
Greenish yellow spot only means one thing. You have a defective lite engine. The only fix is to replace the engine. This part is very
expensive. Average cost $835.00 Part number A-1606-008-A
Best regards
circuitcity
Posted on Dec 09, 2007
  • 48 Answers
SOURCE: Sony KF-50WE610 LCD projection TV. no picture but flashing green
Replace the lamp as they dont last for long
Posted on Feb 01, 2008
ahughs
  • 13 Answers
SOURCE: SONY xbr screen problem
It sounds like one of your circuit boards may be going out. I'm sorry I don't have a better response than that.
Posted on Mar 27, 2008
Marrie
  • 563 Answers
SOURCE: Vertical colored lines on Sony KF-50WE610
Hi Lucian
This is a common Mainboard failure problem on Projectors.
The unfortunate thing is that this can only be solved by having the part repaired or replaced.
Posted on Apr 21, 2008
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
Middle of the looks yellowish what could be the problem
the light filter for the blue lcd is fried and needs replacing. common problem with units that are dusty and overheat. unfortunately, many companies don't sell individual parts for the optical engine (where the filter is), so you may have to get the whole engine.
Aug 12, 2009 | Sony XL-2100U Projector Lamp for...
Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
Feb 23, 2008 | Sony XL-2100U Projector Lamp for...
Sony KF-50WE610 Power Standby light blinking and will turn on seemly randomly for a few seconds with sound and display the shut off and begin blinking again. A purple blob appeared a couple of days ago in...
lamp has probably gone out, but, if when you replace lamp purple blob is still on screen then light engine is bad, need to call Sony and see if is on extended warranty.
Aug 10, 2009 | Televison & Video
Blue hue accross bottom of screen - Sony KF-50WE610
You can try doing this, turn on the Tv and select the service menu, if that tint also shows on the menu, it's most probable to be your DMD board, but if it doesn't it might be the video board..
Jul 03, 2009 | Sony Televison & Video
Hi Lucian
Apr 20, 2008 | Sony XL-2100U Projector Lamp for...
Sony kf-60we610 screen in black and white
Hi there
Is this a DLP tv ?
If it is then your colourwheel might need replacement
Mar 18, 2008 | Sony XL-2100U Projector Lamp for...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Kf-42610 blue hue and blue dots on screen
Hi Guys
The Blue dots or discolouration you are seeing is due too the Blue LCD screen having cracked from excessive heat. This normally happens when you have a power failure while the Television was on. This obviously because the Blue LCD sits next to the lamp - the main cause of heat. The correct part number on the 60" is A-1086-952-A. It is very, very ,expensive.
Sorry to have been the bearer of bad news. Good luck : )
Aug 29, 2007 | Sony XL-2100U Projector Lamp for...
Sony KF50we610 blue dots and blue cloud
Check the optical block repair at sony's warranty website...
Could be the problem they have been covering it under a recall of sorts. $1250 for the optical block and they are only doing it until the end of the year so don't waste any time
May 03, 2007 | Sony XL-2100U Projector Lamp for...
Sony XL-2100U Projector Lamp for KF-42WE610, KF-50WE610, KF-60WE610, KDF-60XBR950, KDF-70XBR95 Logo
50 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
