Question about Vivitar 850AF for Nikon TTL Flash
Nikon D80. Vivitar 4600 Flash unit
I would like to know if it is possible to use an old Vivitar 4600 Auto Thyristor Flash gun on my Nikon D80. When I refer to the manual for the camera it warns be against using any other unit than a Nikon one.
    Scholar:
  • 48 Answers
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Posted on Mar 08, 2009
Which of the following Vivitar flashes will work on a nikon D5100? Vivitar auto thyristor 2800 or vivitar electronic flash 1900?
they should both fire, but they were not meant for modern digital cameras, and the auto features the the camera may have won't be able to control this flash. so it just a manual strobe, to set your camera on manual and experiment.
that little pin on the bottom as well as the 2 on the inside of the flash shoe should fire the flash.
good luck.
Sep 13, 2017 | Nikon Cameras
Will it work with my canon rebel xs
You must make sure that the voltage of the flash gun is not too great for the camera if it is then you may damage your camera electrics. Test it using radio triggers off camera.
Dec 18, 2015 | Vivitar Auto Thyristor 2600 Flash Unit 4...
Can I use the Vivitar auto thyristor 2800 on my Nikon D3000?
If it's a 2800D then it's probably safe. If it does not have a D after 2800, then measure the trigger voltage on the flash contacts with a voltmeter. If it's above 8 volts it will fry the camera. It's not TTL so it doesn't communicate with the camera. You'll have to shoot Aperture priority to get proper exposures
Aug 05, 2013 | Vivitar 2800 Flash
Can i use sunpak auto 30 DX thyristor to nikon d7000?
According to this list the 30DX's trigger voltage is borderline for use with digital cameras. You may be able to use it with no ill effects, or it may fry your camera. It depends on the particular unit.
May 12, 2012 | Sunpak Nikon Auto 30dx Thyristor Shoe...
How to use vivitar zoom thyristor 285 with nikon D80 digital camera
DO NOT ATTEMPT TO USE THIS FLASH ON THE CAMERA OR TEHTER BY WIRE. THe voltage will destroy at least the built-in flash function of your camera. either use a radio slave, an optical slave or you can use it on camera if you use a WEIN safe-synch (approx. $70 USD). If you do not have the users guide for the flash, it can be GOOGLED. Search for "VIVITAR 285 users guide"
Dec 14, 2010 | Nikon Cameras
Can I use my old auto thyristor 550FD on my new Nikon D90 DSLR
No. The high trigger voltage in your old unit will damage your D90 for certain.
You need to get a newer flash (US=strobe) designed for digital cameras but don't have to stick to Nikon's overpriced offerings. Metz are excellent and have a high resale value as you can change the dedication model to suit different manufacturers.
Oct 05, 2009 | Nikon D90 Digital Camera with 18-105mm...
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
I'd like to know if I can use a Vivitar 2800 flash in a Nikon D80 safely. I've been using it, without any problem, but read that maybe this flash can be dangerous to the D80 and I want to be sure. Thanks.
Yeah Rolo, I read that too. I would put a slave unit on your Vivitar, and the Master would be the pop up unit on the camera. Not only will you save risking your camera with the voltage of the flash, but your pictures will be better too. I use Aperture Priority on the camera and AUTO on the Vivitar set to the same aperture
Best regards,
John
Jun 25, 2008 | Vivitar 2800 Flash
May I use a Soligor 24D Flash on my new Nikon D40X Digital Camera
You can purchase an off-camera flash sync adaptor at any good camera store, complete with extension cable.   The should work fine.
Nov 28, 2007 | Nikon D40x Digital Camera
Vivitar 850AF for Nikon TTL Flash Logo
1,263 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
