Question about Bosch Plunge Router
The plunge lock "slips" when the router is used in a table
When used in a table, upside down of course, the plunge lock slips so the router "falls" a few mm.
    Problem Solver:
  • 12 Answers
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Posted on Feb 25, 2009
A screw fell into the little square hole that the plastic cover on sewing bed slides into! Is there a way to access inside machine to retrieve the screw. Baby lock symphony?
If you can, pick up your machine, turn it upside down and shake it. Be sure to put down a towel or something on the table because those little screws will roll or bounce to unimaginable places! If it doesn't fall out, you may find it rolling around inside the case where the bobbin is located.
Feb 13, 2018 | Baby Lock Sewing Machines
I need recommendations on where to get a replacement pressure valve for my Todd English pressure cooker. Seems like a design flaw, there is no way to keep from it falling out.
the pressure valve is just a height sitting on a hole and when the pressure in the cooker reaches such a pressure that it can dislodge the weight , it blows off the pressure and so the pot will not explode
of course if you tip the lid upside down , it will fall off as that is what it is supposed to do
Dec 05, 2017 | Washing Machines
How do you install a ridgid router to a craftsman router table?
Brenda, They are just saying that if the router is too big, it won't fit. The sub-base is the plastic, usually black, disc on the bottom of the router. This disc is about 6 inches in diameter and about 3/16 inches thick. It is usually held onto the base of the router with three screws. The base is the big aluminum piece about the size of half a loaf of bread that has the handles and into which the router main part (the motor) slides into. For most router tables, you mount a router base (with the sub-base removed) to the underside of the table with screws. The router table becomes a giant upside-down sub-base. If your base fits, and the screw holes line up, you are good to go. However, it is very helpful to have an extra router base (without handles) to leave permanently attached to your router table so that you can easily swap the router between the table and normal use. Good luck!
Jan 13, 2013 | Saws
I have a Freud 2000E plunge router. It is about 10 years old, but I've never changed the router bit I have in it before. Now I want to remove the bit I have in, but cannot turn the bolt to remove it....
Hello Davis gr,My name is larry I am an auth Freud service tech.
The first thing to do before you attempt any repairs is of course to unplug.In the full plunged position make sure the router is locked in position out of the table on its side.You twist to loosen the bit nut
and tap gently on the side of the bit with a rubber hammer
turning it slowly and it will come loose to remove.
second--If the router will not spring up to its top position it is because
the posts that are spring loaded are dry.again you must remove the router from the table clean the postd with a dry cloth and while still locked lubricate with lite oil using a clean cloth the metel posts.
after that with the same rubber hammer tap the base plate and it will come loose
I hope this is some help
Larry in Canada larry_boccioletti@yahoo.ca
Sep 11, 2011 | Freud FT3000VCE Router
I have an old router Sears 315.17400 with 1/4 inch bits but no collet, nut, or manual. I'd like to get this working as it is mounted on my new router table and I would like to use my new one as a plunge...
have you tried sears for the collet and nut, should be able to get it there , on on line from there., As far as manual, what questions did you have., I can help.
Mar 25, 2011 | Craftsman Tools & Hardware - Others
Hitachi m12vc fixed router be placed in a router table
does Hitachi make or is there made a 4" router lettering kit?
Dec 05, 2009 | Hitachi KM12VC 2 - 1/4 HP Variable Speed...
How do you attach a router to a router table/plate
With 3 or 4 flathead screws thru the table into the faceplate of the router.
Sep 14, 2009 | Dewalt 2 Hp Evs Plunge Router
Need router for table sears 25479 what new routers fit this table
Hi there. You will find that all of the non-plunging routers will fit. I recommend that you buy the most powerful one you can find for the money you want to spend and one that has a 1/2 inch collet, or ideally both 1/2 and 1/4 inch collets. Enjoy your new router.
Apr 12, 2009 | Craftsman Tools & Hardware - Others
Having difficulty seting bit depth
I'm not familiar with that brand, but no, normally you need only loosen the lock so the router can move up and down, and either twist it or plunge it into the correct position, lock it, check the depth, repeat.
If it's a plunge router you'll have a depth stop rod that you can use in conjunction with the stop nuts to dial in the correct height of the bit. If it's a conventional router you just have to twist it into the correct height and lock it in place without moving it.
If your router table is fairly light and portable, sometimes its easier to turn the whole thing upside down on a pair of sawhorses to adjust, then flip it back over. Otherwise, you just have to crouch down under there, aim a work light so you can see what you're doing, and adjust away.
Make sure you unplug it first!
Also be aware that you might need a fence for your work to ride against, that you may need to make your cut in successive passes rather than trying to hog off too much at once, and that even routers can grab the work and kick it, so be cautious and feed from right to left as you face the bit, (with the work closest to you).
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 12, 2009 | Tools & Hardware - Others
Cannot remove the fixed base
Are you sure the lock nuts haven't loosened and worked their way down the threaded rod to tighten the router down into it's plunged position? That's a really common thing to happen with plunge routers, but without a model number I can't give you any certain advice.
Try breaking those two nuts loose and spinning them back up the stud and see if that doesn't do it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 15, 2009 | Tools & Hardware - Others
Bosch Plunge Router Logo
403 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
