Question about Lenovo 3000 N200 Notebook
How to connect to TV?
What are the wires to use plus where to plug?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Hello, you will have to use an svcd lead plus the red + white audio cables, you will also need to twin view your graphic card, to be able to see the t.v., some newer p.c.'s do this automatically
Posted on Jan 01, 2009
  • blackbelt555
    blackbelt555 Jan 01, 2009
2008 Isuzu cranks but does not start,plenty diesel at injectrs
Hi did you check the glow plugs if not get a small piece of wire plus 12 volt bulb connect it to the wire that connected to the glow plugs turn ignition on and see if it lights if not check the fuses plus the cold start relay after that you can fit a piece of wire from the battery to the glow plugs then try to start it. best of luck let me know how you get on
Feb 03, 2015 | Isuzu Cars & Trucks
Tip
How to wire Phono Jacks/Plugs and Power Supplies.
A, any, MONO Jack/Plug it is always wired the same. There are only 2 wires, one + Plus, Positive. and one, - Negative, ETH, GND. The Minus, GND, ETH, - Negative, always, logically, goes to the or Negative or "Case" ETH, Gnd, those terms all mean the same. Now the + Positive is always Plus,. If the connection is for a Coaxial Cable then, the inner core is Plus +, and the Shield is always - Negative, Gnd, Earth. All Jacks and Plugs wire the same. With a Phono MONO Phono Jack, the "Bulb End" is always Positive, the Case or Outer is - Negative. NOW, IF the Jack/Plug is a STEREO one, then with that type of Plug/Jack there is simply, Two + Plus Wires, and, Two, - Negative, Eth, Wires, these Two, Negatives, Earths all Contact together, and go to the Negative or Outer Connection. The Two + Plus Wires, go, One to each of the tip connection, of the Two Positive Connections, that go to the end, Bulb Tip A & Tip B, of the Stereo Jack./Plug.
For Power Connections the same is generally true, the Centre Conductor is usually Positive, while the other one is - Negative, case, eth gnd.
on Feb 18, 2010 | Computers & Internet
New toshiba tv connect to sky plus box and perfect picture but no sound
The first thing to do is check the connections between the Sky box and the TV. If you are using a SCART cable, it's possible that one of the pins in the SCART plugs has bent or become detached from the wire inside. If you have another SCART cable from a VCR or DVD player, try switching them over.
If this doesn't work, or if you are using another connection method between the Sky box and the TV, please post back and I will try to assist you further.
Regards,
BElectric
Nov 29, 2010 | Toshiba Televison & Video
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Oct 06, 2010 | Harman Kardon Audio Players & Recorders
I need a diagram showing me how to wire a 3.5mm mini jack (input)? Its for aPC Audio Cable.... seems there are no experts who can help as its not in the "products".... plz forward this to someone who might...
A any jack/plug it is always wired the same, there are only 2 wires, + Plus, and - Negative, ETH, GND. The Minus, GND, ETH, always, logically, goes to the or Negative or "Case" ETH, Gnd, all mean the same. Now the + Positive is always Plus,. If the connection is for a Coaxial Cable then, the inner core is Plus +, and the Shield is always - Negative, Gnd, Earth. All Jacks and Plugs wire the same. With a Phono MONO Phono Jack, the "Bulb End" is always Positive, the Case or Outer is - Negative. IF it is a Stereo Plug/Jack there is simply, Two Plus wires, and two - Negative, Eth Wires, these Two, Negatives, Earths or Contact together, and go to the Outer Connection or Negative. The Two + Plus Wires go, One to each tip connection, of the Two Positive connections, that go to the end, Bulb Tip A & Tip B, of the Stereo Jack./Plug
For Power Connections the same is generally true, the Centre Conductor is usually Positive, while the other one is - negative, case, eth gnd.
Feb 18, 2010 | Polk Audio IBM PC 300PL Mini Tower...
Why is it that when i try to connect the satellite it shoots sparks and burns the f#@$ out of my finger... dynex 32'' lcd flatscreen
The cable shield is not correctly grounded or Sat box is faulty. The tv plus or wall ouytlet may not be correctly wire. The tv plug is polorized for a reason. There is a voltafe potential between the cable shield and the tv ground. not good. Call electrician.
Dec 03, 2009 | Televison & Video
How to connect bush active subwoofer to tv
is there red and white jack plugs in the back of the sub? if not just th wire only connections you need an amp plus the amp will have a low filter pass so the sub will work at its best, better option by a low end L.G surround sound complete with 4 speakers a sub and amp the quality is realy good
Aug 29, 2009 | Audio Players & Recorders
How to i hook-up a directv dvr plus to two tv's?
plug one tv using coax (screw in cable). plug the other using composite video cables( yellow, red, white). It will be easy to connect the tv that's the farthest with coax, its cheaper to purchase 50ft of coax vs 50ft of composite video.
Jan 03, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Router problems
Please answer the following questions --
Is this a new router installation?
IF so -
  • Who is your internet service provider?
  • If they are Cable TV based your wan side router configuration might be correct.
  • If they are Telco (phone line) based your wan side router configuration probably needs to be updated.
How is the connection wired
  • Starting with the cable tv coax or a phone wire plugged into a phone jack
  • Does this connect to a box provided by your service provider? (probably a modem/whatever box)
  • Does an ethernet cable (looks like a fat phone wire with wide connectors on the end ( 8 metal connection points) -- connect the modem to a single port not in a group on your router?
  • Does another ethernet cable connect one if the block of four ports to your computer?
If so you appear to be wired correctly
If not explain to be in the same order preferably how your equipment is wired.
After you reply I will provide additional steps.
Jan 02, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Lenovo 3000 N200 Notebook Logo
49 people viewed this question
Top Lenovo Computers & Internet Experts
Brian Sullivan
Brian Sullivan
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
