Question about LG KU990 Viewty
LG KU990 -Invalid Access to Memory Location
I bought a LG Viewty in August and i could connect it to my computer and doowload all my pictures and videos. But now at the end of december it wont let me. All it says is: Invald access to memory location. HELP !? please!
  • 2 more comments
  • miss_chloe_b Jan 03, 2009
    Thanks for the comment but i did that and that didnt work. However i have solved my problem too. It was because i had windowss vista and LG pc suite is not compatible with that. To make it compatible you have to:
    -right click on LG pc suite.
    -click on properties.
    -click on the compatibility tab.
    -check the box which says Run the program in compatibilty mode for: (windows XP service pack 2)
    -Then try again! =]
    Hope this helps anyone x
  • Anonymous Mar 19, 2009
    i opened my LG pc suite for KU990 Viewty, but it keeps saying 'invalid access to memory location" everytime i clicked Contents. i tried almost everything - changed firewalls, turned off parental control, fixed it in the 'properties' and compatibility, but it STILL WON'T WORK.
    it's driving me crazy...what can be wrong with it?
  • Anonymous Apr 15, 2009
    I have excatly the sam problem. So I unistalled it completely and it worked a few times and then it started doing it again!! Sometimes like very rarely now it will work but most the time it doesn't!
    I tried the 'compatibility' thing and it still didn't work, its really fustrating me, what the hell is wrong with it!!!
  • Anonymous May 10, 2009
    i have tried everything even re-installing it! it is not working HELP what do i do please
I had the same problem and thanks to another user on the website I have now fixed mine.
Unistall everything to do with LG on your computer and disconnect your phone. Start from scratch and install everything again.
It worked for me and took about 10 minutes.
Good Luck
Posted on Jan 02, 2009
My lg viewty wont let me access the contents through the lg pc suite. Its keeps coming up with invalid access too memory location. How do i fix this?
Go to 'Menu > Settings > Connectivity > USB connection mode', and select 'Data service'.
Hope it works for you.
Cheers! Carlos
Mar 18, 2010 | LG KU990 Viewty
Invalid access to memory location with LG KU990
Disconnect he phone from the USB.
Open your phone menu.
Open the phone settings.
Open te USB connectivity.
Change te settings to Mass storage.
Connect the phone to the USB port.
If windows reconize the phone as a removable drive the you can
drag and drop your files in the explorer. When you saved the files on your pc then format the card in Fat 32 in a card reader from your laptop or pc or by a extern card reader.
Whe the format is done you can drop the files back.
Set the settings in USB connectivity back in Data service when
you are done.
Swich of the phone and put the card back in the slot.
Now the phone will reconize your memmory card.
hope this will help.
May 27, 2009 | LG KU990 Viewty
LG PC Suite won't work! > "Invalid access to memory location"
Try this:
Disconnect your phone from the USB.
Open the menu on your phone and go to phone settings.
Now choose Connectivity.
Go to USB connection mode.
Choose Mass storge and select it.
Now connect your phone to the USB port.
This way your phone will act like a extern USB HardDrive.
Open your Explorer browser in Windows and find the removable
drive.
Now you have the option to drag and drop any files between your
LG Viewty and your Pc or Laptop.
When you finished the job you had to do change the settings back
to Data service on your phone.
This will help you out to get the files witout LG PcSuite.
Apr 20, 2009 | LG KU990 Viewty
I cant transfer pictures from LG ku990 to pc
Go to Connectivity in your phone settings under the settings submenu.
Select it, and change it to mass storage, if you have an SD card, you can use this to put files onto your computer.
Apr 11, 2009 | LG KU990 Viewty
Problems with LG KU990 Viewty
try swappin to mass storage mightwork ,, my phone has a problem too ,, wil not play videos recorded from camera ( avi) it jus says -- not supported -- then exits, then my memory card disappears, soo annoying.
Jan 12, 2009 | LG KU990 Viewty
Lg ku990 problem
turn ur phone off untill the screen on ur computer says "no phones connected"
then turn your phone back on
and connect as usual....
trust me it works.
Dec 23, 2008 | LG KU990 Viewty
LG PC Suite
Im going to tell you the safest, fastest, and Easiest way to do it, but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections on your phone.
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo....
  • 2.Select setting
  • Press Mass storage
  • Press OK.
  • 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's Or the LG PC Suit.
    And Welcome to the Viewty Family! Enjoy...!
    Dec 13, 2008 | LG KU990 Viewty
    LG KU990 USB Connection Problem
    in order to send photos,music etc to ur phone u just have to go to phone settings>connectivity>usb connection mode and select mass storage. then use the usb to connect the phone to the computer and that's it.
    Jun 24, 2008 | LG KU990 Viewty
    LG KU990 Viewty Logo
    1,312 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
