Question about Vacuums
Is it worth putting in a brush for an old hoover convertable?
    Genius:
  • 2,920 Answers
Be better to get a bew vaccuum
Posted on Jan 01, 2009
My Hoover floormate motor started smoking. It is over 9 years old. I keep the floor brushes clean. I am wonder if replacing the mother is worth it.
MSRP on this motor is $69.95. Labor may be another $30.00. I often see these units in thrift shops, which may be worth a try.
Jan 29, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
My machine (Hoover Wind Tunnel - bagless) is only 1 yr. old. The agitator brush doesn't turn all the time. I know it's not supposed to turn when in the upright position. However, it only seems to work when...
Sounds like you should do two things: 1- Remove and clean the beater brush of all debris as best you can. At the end of the brush you will see a hard rubber piece, at both ends, that holds it in place in the body of the vacuum. Add some WD40 between the brush and these pieces and turn until they move freely. 2- When you reassemble, put a new belt on.
This should be all you need to do. If you find this information to be of help, I would appreciate a Thumbs Up from you. Be well, Paul
Oct 08, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Old Hoover Convertible Upright U4109 keeps breaking belts. I just replaced the belts twice and both broke within 2 minutes.
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Sep 05, 2010 | Hoover Vacuums
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Brushes don't turn. Handle pulls away from tanks
Used it as it was. Clean enuf. Not worth waiting for solution and not worth taking it in for repair.
Jan 30, 2010 | Hoover Vacuums
Brush wont spin, belt is perfect
It sounds like the motor that spins the beater brush is burned out,If it is under a yr old it should be covered by the manufacturer warretee. Find a Hoover service center that does warrentee repairs.
Jan 25, 2010 | Hoover U8188-900 Bagless Upright Vacuum
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
How do i change belt on my hoover sweeper
get a fillipshead screwdriver, put the vacuum facing you so the brush is infront of you, you will see 4 screws on each corner.unscrew those and when you do there will be a space where you will see a shaft that points out. take the old belt off and put one part of the new belt on the shaft and the other part on the brush near the belt. (there will be a little brown part on the brush for the belt to lay on) make sure its secure and screw the screws back and your ready to go !
Sep 09, 2009 | Vacuums
Hoover U6634-900 self propelled, brush belt keeps coming off.
unfourtunatly it could be the height of your carpet also using on area rugs could cause it to do that too. check the brush roll and make sure it is spinning freely.
Aug 29, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Vacuums Logo
18 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
