Question about Hamilton Beach 702R Food Processor
Won't come on at all
I've been a bad food processor user and left it sitting on the shelf for a few years and decided it was time to start using it again to make baby food and now it won't come on. any suggestions?
  • marlo414 Dec 04, 2008
    Purchased this item at a fair yesterday and I haven't a clue as how to use this item 702R Hamilton Beach food processor., I need the instruction manual, Please help.
If you do not have the main dish hooked up correctly it won't come on. I don't know the correct terminology, but there is a lip on the clear cup that slides into the control panel on the left side. It must be a safety major, because if that is not in place it will not work. Hope this helps. Don't throw it away. Deanna
Posted on Jul 30, 2008
SOURCE:
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
Oct 29, 2011 | Cuisinart DFP-14BC Custom Food Processor
UstMy dughter gave me a Little Oscar food processor but it has no instruction manual. Where could I buy one please. Thankyou Gaile Erceg.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link
Jul 31, 2011 | Sunbeam 4816-9 Food Processor
How to use my food processor I have had it for a couple of years and never have used it Bravetti Platinum Pro Quad Blade 6 Cups Food Processor
I went to my user manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts. I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
May 28, 2010 | Bravetti Platinum Pro Quad-Blade Food...
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Replace Rubber 0 Ring for GE Food Processor Inside Diameter 2 6/8
I decided to trash my 19 year old GE Food Processor that needs a new gasget and puchase another.
Thanks for your interest.
Samella 124
Apr 09, 2009 | GE Food Processor
Need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Dec 07, 2008 | Cuisinart DLC-5 Food Processor
Euro pro food processor and blender combo
Defective pulse button or blender attachment not installed correctly.
Sep 12, 2017 | Euro-Pro EKP110 6.25 Cups Food Processor
Food processor
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food Processors Logo
214 people viewed this question
Top Hamilton Beach Food Processors Experts
Barb
Level 1 Expert
eyecam
ray gallant
ray gallant
Are you a Hamilton Beach Food Processor Expert? Answer questions, earn points and help others
