Question about Furuno 1715 LCD Radar System GPS Receiver
Screen will not shoh target
The radome rotates, screen shows rotation, but will not display target. I,ve misplaced my manuals, any sugestions? Wayne
I have a Sylvania GPS Model SGPD432. My question is how do I get the screen back to sideways instead of up & down
From the GPS window, select settings. If you select the right arrow in the bottom other icon /options will appear. Select the one that says rotate display.
Jul 27, 2012 | Sylvania SGPD430 GPS Navigator
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
It sayspressand briefly hold stylus on the cenyer of the target as the target moves around the screen it dose nothing at all
when it says press and hold briefly it means tap and hold briefly, and then follow the target, it is just to align the screen for your map display
Jan 31, 2010 | GPS
My radar displays all contacts reverse. How do I get the display reversed? model #1731
I agree with Nico-Fixus, the heading alignment is one of the things to be checked. Unless this is a new installation it is unlikely that the Radome (antenna) got removed and reinstalled facing the wrong way. So antenna orientation would not be a concern.
I have seen units that for some reason the wrong Radome was selected in the configuration of the Navnet display.
Read the model number on the Antenna, then check that correct antenna type in loaded in your display.
Oct 22, 2009 | Furuno Navnet 1732 GPS Receiver
Won't pick up satellite
Have you tried resetting the device (you need paperclip to do this on the bottom of the device)?
Have you tried removing the SD card and re-inserting it?
If you go to the menu, click "Change Preferences", then scroll to "Configure GPS" and click it, you should see the GPS Status screen.
It should look something like the photo below, showing satellite signal strength at the bottom of half of the screen.
You should also see in the top right corner next to the time a black and yellow circle that rotates 80 degrees every second. It rotates every time a message is received from the GPS chip.b4a398e.jpg
Jul 13, 2009 | Tomtom ONE GPS Receiver
Uniden trax 430 frozen
I have had a similiar problem with my Trax 430. The screen freezes at the system shut down stage. I have to plug it into the computer via the USB cable. It then recognizes the computer and attempts to do an USB update. Then just unplug it. It should work but not a practical solution when you are driving about.
Jul 10, 2009 | Uniden TRAX-430 GPS Receiver
Furuno 1715 Radar - 'NO HEADING PULSE'
More than likely the belt has come off again. This is a common problem with this radar. You'll need a small allen wrench to tighten it up again.
Jul 02, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Garmin ique3
It sounds like you don't have the road maps disc for North America installed.Call Garmin you talk to a real person,that really knows their stuff,and will walk you through any problem.
Jun 27, 2008 | Garmin iQue 3600 GPS Receiver
Display
It sounds to me like there might be a video processing problem in the scanner radome, or a break in the interconnect cable that runs from your screen to the radome.
If you did any work onboard recently that might have disturbed the interconnect cable please revisit the scene. If there was any kind of splice in the cable something may have come loose.
If the normal checks of tight, clean connections, adequate power to the display (which feeds the radome) don't revel anything, you may wish to call Raymarine or a local service dealer.
Dec 02, 2007 | Raymarine RL70CRC GPS Receiver
Furuno 1715 LCD Radar System GPS Receiver Logo
Top Furuno GPS Experts
Ron Dufek
Ron Dufek
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
