Question about Mitsubishi WS-65513 65" Rear Projection HDTV
WS65511 Mitsubishi rear projection tv
I have replaced the 7 caps, 2- 5amp picos and STN 383-110. Still set turns off immediately. If I press menue and device I get 2 blinks followed by a pause and 2 more for six or seven times. I have unpluged and let it run thru the fast blinks until that stops. Then I turn it on again and same 2 blinks. Have checked transistors and other caps and all seem ok. Any ideas????
    Genius:
  • 2,920 Answers
What about the deflector?
Posted on Jan 01, 2009
Blinking green light
Replace the 7 capacitors on the DM board. That should solve the Issue. You can get the Mitsubishi WS48511 - WS65511 DM repair kit from www.tvrepairworld.com which has the upgraded replacement capacitors and the CD with repair instructions.
Jun 19, 2012 | Mitsubishi WS-55511 55" Rear Projection...
My tv is a mitsubishi model ws65511 our power went out when it come on tv wont work just flashes green reset wont help
thats caused by failed DM caps which discharge during power outage and then cannot be recharged when power is restored. the mitsubishi repair kit called the WS48511 - WS65511 DM repair kit available from www.tvrepairworld.com should solve the issue it has the replacement capacitors and the CD with repair instructions.
Jun 02, 2012 | Mitsubishi Televison & Video
I have a mitsubishi rear projection tv model ws65511. When i turned it on this morning all the timer light started to blink green. I tried to reset and it still blinks. unplugged and plugged back in and...
that's a very common problem for that model which is almost always caused by bad DM capacitors. Replacing them should solve the issue. You can get the Mitsubishi repair kit called the WS45511- WS65511 DM repair kit from www.tvrepairworld.com which has the caps and the CD with detailed repair instructions.
Oct 04, 2011 | Mitsubishi WS-55805 55" Rear Projection...
I have a convergence problem on my Mitsubishi 65 inch rear projection tv (model number WS65511). I see red double images on all four sides. Middle of the screen is OK. Which IC Mitsubishi use STK393-110...
Your model is the V21 chassis it requires the single IC STK393-110 you will also need 2 5 amp pico fuses. The convergence repair kit is available for your model at www.tvrepairworld.com which contains the IC, heat sink paste, the pico fuses and the CD with repair instructions and other service info for that model.
Jun 10, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
May 31, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Tv won't stay on
You need to replace one STK393-110 and 2 or more 5amp pico fuses. Very common problem.
Jul 03, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I HAVE A WS55859 , TOOK IT TO A TECH AND HAD 7 CAPS REPLACED BECAUSE OF BLINKING LIGHT AFTER POWER OUTAGE NOW AFTER 150.00 SPENT THE TV IS NOT BLINKING ANYMORE ONCE I TURN THE SET ON IT WONT STAY ON IT...
Did the set work after the tech replaced the caps?
Is the work under warranty?
Bad convergence amps would be the first suspect.
Press and hold the menu and device buttons at the same time on the set (not the remote). The led should blink an error code. If it blinks 2 times then 3 times, it is probably the convergence amps.
Sep 10, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Need to reset Mistubishi 48 rear projection tv.
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "2", "2", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
This will reset the the tv ....
Feb 18, 2009 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green light will not stop blinking
often the capacitors will show no visible sign of swelling. 90% of the time the blinking light symptom is caused by those capacitors
May 12, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
