Question about Wharfedale Televison & Video
Sound but no Picture with Wharfedale DVDR24HD160F
I can get sound but no picture and theres a line down the middle of black screen. Have no freeview signal so that wont work here. Wharfedale DVDR24HD160F. I have scart leads in correct as I have a Philips Recorder set up with no problems
  • marywhelan12 Jan 02, 2009
    THIS IS THE SOLUTION: (I tested it when I got the machine back home)
    If you press HDMI button on remote you get a blank screen (but the DVD still has sound)
    Press it again and nothing appears to happen (although apparently the DVD is switching to another mode)
    Press
    the button yet again and WAIT (I counted to 10!) then the DVD reverts
    back to AV or whatever you call "normal" tv and everything is OK again!
    (on some models you might have to press the HDMI button a fourth time
    but the message is to wait a bit for the DVD introductory screen to
    appear - it does not happen instantly)
ProMonkey
  • 59 Answers
SOURCE: Wharfedale DVDR24HD160F No picture on TV and SET UP on display
check the leads our pushed in firmly, then turn the dvd player off leave for 5 - 10 mins turn back on and hopefully setup instructions will be displayed on your tv follow them thro and that should fix your problem :D
Posted on Mar 10, 2009
cookieboy
SOURCE: Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Posted on Jul 01, 2007
  • 123 Answers
SOURCE: find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Posted on Jul 29, 2009
  • 208 Answers
SOURCE: Wharfedale DVD recorder, no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Posted on Mar 18, 2010
SOURCE: im looking for wharfedale dvdr24hd160f recorder
Could be a problem with the SCART vs HDMI output. Try CLEAR-CLEAR-4 to reset - worked for me!!
Posted on Apr 16, 2010
Wharfedale DVDR24HD160F NO PICTURE ONLY SOUND
try the scart leed from your tv to your dvd give it a wriggle if not buy a new scart leed
Nov 17, 2011 | Televison & Video
Have an lcd2010a wharfedale colour tv since 2005. It is out of warranty. Problem. switch on tv obtain sound and picture for 1 to 2 hours or even less 45 min. Then suddenly no picture, but sound or nothing...
try removing and re-installing the lamp cover on the back.
its a known issue with whaferdale tv's during manufacture, the lamp cover is not seated properly causing the safety switch to not engage all the way, when the lamp cover heats up and expands, it fall away further from the switch tripping it, shutting the set down.
when you remove and re-install the lamp cover, after you take the single ***** out, tilt the cover out and forward from the top about 3/4 of the way out and then tilt it back into normal position and put the ***** back.
Mar 11, 2008 | Televison & Video
Screen has black line down the middle.
it sounds like a setting in the progressive scan or screen ratio menu.
May 04, 2009 | Video Game Consoles & Games
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
Mar 10, 2009 | Televison & Video
Dvdr24hd160f sound but no screen
Check out the thread at http://www.pcadvisor.co.uk/forums/index.cfm?action=showthread&threadid=311178&forumid=21 sounds like the same problem (pressing the HDMI button in error) the solution is towards the end of the thread.
Dec 11, 2008 | Wharfedale DVD-M3 DVD Player
Trying to play a disk on my Wharfedale DVDR24HD160F and all I get is the word ROOT coming up on the player front and the player stops.
Dear Team. I was getting vision but no sound or sound but no vision a right dogs dinner of a mess. What I decided to do was to run the recorder by applying the facory defaults. This reconfigured the freeview side and also it corrected the fault because on setting things up afterwards the recorder did what it was supposed to do. Hope this is a help and thank you for your interest. Dave.
Aug 29, 2008 | Wharfedale Televison & Video
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
Televison & Video Logo
286 people viewed this question
Top Wharfedale Televison & Video Experts
Gareth Cockram
Gareth Cockram
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
