I can receive calls but i can't call out i've tried 9 and 8 and 98 ...89 you name it i've tried to get an outside line i can call internal ext but that's it heeeeeeeeeeeeeelp
SOURCE: meridian M7310-shows outside line in use and cannot disconnect
the easist way to reset that is to reset the system. unplug it for a moment that should clear it.
SOURCE: Hi, Can any body help us? We have a M7324 on a
On the cross connect do you have a CO connected to that line. That is most likely the cause of no dial tone. If you don not know how to check that call a phone system expert to connect and verify your system.
SOURCE: How do I activate the
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
Regards
